Hurseyc
I started with working manual disc/drum brakes and went to a vacuum power setup and having some problems. I've been reading a lot of the brake conversion threads and am just looking for some thoughts.
BTW - Front is the Chevy disc conversion.
After initial install of the power setup I couldn't get them bled and couldn't get any pedal. I figured out the rod (into the MC from the booster) was adjusted out too far and the MC was never "releasing". Once I backed that off, it seems to have bled well and I instantly got some pedal.
So at this point the brakes are pretty good but not great, and each time I take it out there's LOTS of brake fluid shooting out of the MC. Looks like from the front which on my MC is the bigger side and going to the front brakes.
When I say good, I mean the effort is good and it stops okay but I feel like the pedal goes down further than I'd like and I can hit the floor without locking up either front or back.
I've read that often the cap needs to be hose clamped on to stop the leaking. It looks like the cap is seated correctly and the bales are tight. I'm wondering if I need to try the hose clamps or if it sounds like there's still too much back pressure and it's squirting out.
Any chance I need to adjust that rod any more or once it's working is it pretty much a done deal?
BTW - Have the GM style prop valve and recently had to replace the plunger thing due to a leak so I'm not 100% sure that thing is working correctly.
I'm considering going to a setup where it's direct to the front and a manual prop valve to the back but I'd like to have this sorted out before I go making huge changes and cause more problems.
Anyway, thanks for reading and let me know what you guys think.
Chris
Chris
