Could someone please tell me the difference in small and big bearing rears is ? What do the big bearing rears come in ? How much is a dana 44 with discs for a EB worth ? thanks for the help
This is a total guess, but I think there is actually 3 diff size bearings. I have a 75 and it has the big ones and the 76& 77's also have the big ones. The others are small I think.
[quote author=2badrotties link=board=5;threadid=10163;start=0#73366 date=1034565328]
[/quote]
Broncos came with 2 diff. GVW's the light one had small bearing's and the HD had big bearing's My 66 is a BB rear end . My ford paper shows sb @ 2780 and bb @ 3300 this is for the 1969 hope this helps you. Bill 8) :
Big Bearing has a Big bearing and 1/2 bolts that hold axle plate. Medium bearing has big bearing and 3/8 bolts holding axle plate and I havent ever seen any other ones.
10" Drum with P/N 55264 on Backing Plate = Small Bearing (2.834" diameter)<br><br>10" Drum with P/N 80174 on Backing Plate = Large Bearing (3.15" diameter).<br><br>11" Drum with P/N 319130 on Backing Plate = Large Bearing (3.15" diameter).
Thanks for the info. I finally found a parts truck ( 66 bRUSTco half cab ) and the guy gave me a dana 44 with disc brakes and another 9 inch rear. I was wondering if the 9 inch is stronger than the one in my 69. I'll figure it out. Thanks again
I've actually got Torino ends on mine(thanks to a mixup at Curries). Chuck(BC Broncos) says he sees this often enough that he's going to rig a disk conversion for it too. I believe the bearing is the same size as the EB big bearing but with different measurements on the bolt pattern.
<br>28 splined rear ends came in<br><br>66-75 Small brg<br>74-75 Medium brg<br>66-77 Big Bearing<br><br>31 splined rear ends came in<br><br>66-75 Small brg<br>74-75 Medium brg<br>66-77 Big Bearing
[quote author=2badrotties link=board=5;threadid=10163;start=0#73624 date=1034646210]<br>Thanks for the info. I finally found a parts truck ( 66 bRUSTco half cab ) and the guy gave me a dana 44 with disc brakes and another 9 inch rear. I was wondering if the 9 inch is stronger than the one in my 69. I'll figure it out. Thanks again<br>[/quote]<br>2bad, Let me know if you need a hand with anything. I'm right across the river.
Where were you this morning ? I went out in the monsoon and couldn't put my roof on all alone.Right now the only hand I need is finding me some more Broncos for kinda cheap. I have no retirement plan at work so I'm trying to come up with a new game plan. I would like to meet you some time. When I start working on something I'll be sure and let you know
