oldiron
- Jul 21, 2005
- 1,032
Need a little direction on this one. I just got the new harmonic balancer installed (Thanks Wild Horses), so that I can finally accurately time this engine. At first, initial timing (set by ear) was at 26 but idled great.
I backed that off to 12 degrees. Idle is a little rough but I'm still dialing in.
Problem is this: 12 deg initial...12 deg mechanical at 2500...but I'm getting 16-18 deg from the vacuum advance which is ported. With that much vacuum advance, and more initital timing (that this engine really seems to like) it adds up to way more than is allowable and the engine starts to break up at higher rpm. Any ideas? Is there a way to adjust the vac adv downward? This is an '86 5.0ho roller engine long block. The dist is an off the shelf unit for an '85 gt.
Greg
Greg
