- Jun 13, 2007
- 1,790
Cage for sure as everyone else says. Make sure its tied into the frame for even more structural integrity.
Very nice! Good luck with it. Ken
the only thing I would do to that Bronco is go through the steering, brakes, clean out the fuel tanks and do a good tuneup and go enjoy it. then you can fix the little things as you drive it. o and put new tires on. great looking Bronco, congrats
What he said^^^. Looks like an awesome truck to start with, and the fact that it was your Dad’s makes it that much more special. Congrats and enjoy, welcome to the addiction!
30x9.50 BFG ATko 2's would be my choice for your Bronco. I have a set on my 74 an really like them, they are quieter, smoother an better in snow than the old bfg at's. don't blame you I wouldn't lift it either
Appreciate the tip/info. Yeah, I don't want to lift it, so I guess I'll be pretty limited on tire size based on the wheel wells and especially that rear fender. I just think I want that stock/vintage look.
Hey all,
Bronco is in the shop and getting estimates for all the work I'm going to get done -- new steering wheel (like original), front disc brakes, belts/hoses, distributor/ignition, vintage air conditioning, new tires (BFG 30x9.5r15), rear wheel cylinders, add power steering, and new fuel tank. May also let them put a rear bench in. Roll cage coming later.
Need advice from you experts on a couple things:
a) currently has dual pipes going out back, fairly small diameter, small glass packs; actually sounded pretty good when I heard it yesterday. My dad says you end up getting a lot of fumes in cab while driving b/c top is not air-tight, suggested taking pipes out the sides. Any thoughts? Would it be better to just get rid of current setup and go back to a stock set-up?
Exhaust should go out to the side and end past the body.
Fumes are sucked toward the back of the Bronco by the low pressure there, which is why out the back is bad.
Out past the body because fumes rise with the heat of the exhaust.
b) 2-barrel carb needs to be rebuilt ($450) or replaced; shop has suggested putting a 4-barrel Edelbrock in its place (about $1600). Fairly big price difference, but sounds like it could be worth it for more performance/power. On the other hand, as I'm keeping this thing fairly vintage/survivor, would you view this upgrade as being tacky/tuner? Any drawbacks to going from 2 to 4? Keep in mind, I'm not much of a gearhead, so keep the explanations simple, please.
A rebuilt Autolite/Motorcraft 2 barrel is a much better carb for a mostly stock Bronco.
Thanks in advance.
