Replacing King Pins Need Advice
bluemonday
South Louisiana
Replace your bearings, axel seals, locking hubs if needed. Call one of the part houses to make sure you have all seals and bearing before tearing into it. I don't remember every step but it was a pain. Get a drawing of whatever axle you have and study it first. Blow it up copy machine so you can see every part. And some cold LoneStar for after the work.
KyleQ
If they fight you, take a cutoff wheel and cut a groove at the base of the kingpin all the way around, ~1/4" and heat it up with a torch, works sweet on a D60.
