Need Help Find this Speedo Cable
Twin Cities
Bronco experts...... Novice bronco owner here trying to replace his speedocable... after visiting numerous parts store I have figured out its not a stock cable... Hoping someone can point me in the right direction to find this style of cable....
Thanks for the help
Bronco Junkie
So Cal Broncos
Hmmm...I recently replaced my speedo cable and the ends of my old cable look like this.
Do I pull the plastic looking gear of the old one and place it on the new one?
Yes, that is the speedometer driven gear. You use different gears to correct the speedometer for various gear ratio and tire size changes. If you need the speedometer to read faster, use a gear with less teeth. 16 is the least teeth available.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You re-use the old gear on the new cable. See the little metal clip at the end of the gear? Take that off, remove the gear, and your cable will look just like all the other ones pictured.
The cables don't come with the gear because there are several different gears available depending on your gear ratio.
If you need a new gear, you buy that separately.
