Well since I basically destroyed my powersteering pump pulley and threads I decided that it is time to upgrade the system and make it look nice. Instead of buying a saginaw pump from one of the bronco houses I decided to put together my own kit. I purchase a fully chrome GM style Saginaw pump to liven up the engine compartment more (Pump is from speed shop-hot rod). Then I purchased the wild horses zinc plated bracket and that seems to match up perfect. So the install should be fine. Pump looks to be teh same size at the one sold by wild horses. So now I need to figure out the high pressure hose. I have a brand new factory hose but the one end does not match up of course and everyone said there is not adapter to adapt from the different type ends. So I have come to the conclusion to attempt to make my own hoses out of high pressure stainless steel braided line with AN Fittings. IS THIS possible? I have never used this type of system and I don't know that I can get the correct ends. I think they would look really nice and again add to the appearance. This whole custom set up I think will still run me less money then a kit from the bronco houses.Anyone have suggestions for making hoses or if it will work. Whats size hose should I use for the high pressure line- 6 or 8 AN I don't even know what that means. Swivel or non swivel ends??? Please help me-if you can make them let me know I may pay you to build me them. I was also thinking of using steel braided lines for the master cylinder to the prop valve to?
kyle
kyle
