Sc300insc
I purchased a 1977 bronco with a fiberglass body in February. It came with what I thought is 2 1/2" suspension lift 2 " body lift. Had blocks in the rear and I believe stock leafs. And had coils in the front that measure 18" out of the vehicle. Believe they are rancho springs
Both driveshafts where installed when I bought the bronco
I have taken it down to frame installed a 2 1/2" suspension with new leafs. No blocks. Same shacks. Same engine Trans and Dana 20. Had the rear end services all new seals and bearings. Front drive shafts mounts with no issues. Checked to see if leafs where installed the correct way. They are. They have the kink near the eyelet in the back. The rear shackles are I believe the correct direction the open side is to the rear. With all the leaf spring shackle bolts loose and the the frame lifted off the ground. I pushed the suspension to full drop with pry bar and the drive shaft is still too long.
The bronco has a fiberglass body and it off the frame so it should have even more space.
The rear driveshaft is fully compressed to it shortest length
Not sure. It this had a lenghten drive shaft. Wondering what was shock length
When it is sitting on the ground the rear shackles are at 12 o'clock. Straight up
Pictures to come when I can figure how to add them
