easyg
Here is some background: 75 with 302, C4, power steering 1" body lift, old 3" rancho suspension lift?, 33 BFG's A/T
OK I recently installed the body lift and while prepping to do so I noticed the rag joint was looking worn so I decided to replace it with a new lower shaft with U-joints.
Ordered one up from WH timely delivery no problems. These shafts are pieces of art, they are expensive but worth it IMO. Back to the problem.
Everything was going fine until it came time to remove the rag joint coupler that is pressed on to the bottom of the steering shaft at the end of the column.
It would not come off. I tried every puller I have to get this thing to move with no luck. Applied heat that didn't help. (I have been soaking all the components with PB blaster for the last week.)
The cave man in me came out and I ended up cutting some slots in it to try and break it off. Finally the F'n thing came loose.
What I found was that the end of the shaft was mushroomed so the coupler couldn't slide off. Not sure how this could have happened??
Now I have splines that are boogered up and the shaft is mushroomed and there is no way to get it to mate up.
I have pulled the shaft out of the column and I am getting ready to start grinding. I doubt I will be able to salvage this but I am going to try.
Nobody sells this shaft you have to buy a whole new steering column. Does anybody know of a source for these or other Ford applications that use the same shaft?
Steer me in the right direction so I can get this mess turned around.
