Need help- wonÂ’t run
Blue1969
Blue1969
Wouldn't a failing/failed fuel pump check all the boxes?
You could try gravity feeding from a jerry can right to the carb inlet to rule out your pump, but maybe I'm going down the wrong path.
Sent from my SM-T560NU using Tapatalk
I think I'll try gravity feeding to rule out the fuel pump before I pull the carb off.
I appreciate everyone's input!
Blue1969
Blue1969
I assume you plug the line from the pump to the carb?
gnpenning
Bronco Slave
Correct me if I'm wrong, but you have only mentioned issues at idle and low rpms
If you were having problems under load or at higher rpms then a filter or pump would make sense. Fuel demands are far greater under loads and rpms compared to idle.
No harm in testing volume and pressure of the fuel pump.
Blue1969
Blue1969
I rebuilt the carb over the weekend, but still have to tune. How do I post a pic of my fuel bowl contents? There were black flakes in the bottom.
black flakes as in rust or rubber from the fuel lines or the fuel pump. cut your fuel filter open. trash in the carb could have been there a very long time.
Blue1969
Blue1969
I will look closer this afternoon. I don't think it's rust, but I will fell to see if it might be fuel line.
When you say cut the filter open, do you mean the metal one that screws into the carb? Die grinder to cut it open?
gnpenning
Bronco Slave
If you use a die grinder be sure and video, make sure you are outside. Sparks and fuel are not a good mix. On the bright side there isn't much fuel.
Blue1969
Blue1969
This is what was in the bottom of my fuel bowl.
Blue1969
Blue1969
Should I be concerned about deteriorating fuel line on my newly rebuilt carb?
gnpenning
Bronco Slave
Depends on how much you run it before replacement. Don't assume that your local parts store fuel line will be compatible with ethanol. Go with marine grade A1, recent thread on the subject. Don't forget the lines from the tank and switch over valve if you have one. I would suggest blowing out the hard lines while you have it apart. Be sure and rotate the switch valve. Careful with pressure on the valve and charcoal canister etc.
Blue1969
Blue1969
Thanks, I'll get some A1 marine hose. I appreciate your input. Single tank and no charcoal. 69..
Blue1969
Blue1969
Thanks for everyone’s help. I replaced the nylon fuel line from the tank to the fuel pump with A1 fuel hose. I found a kink in the nylon line back by the tank when I replaced the hose and determined that was the culprit with the stalling. I drove it to get some non-ethanol and it ran great for about 4 miles with no stuttering or stalling and idled well. At about 45 mph, I accelerated fairly hard and the truck bucked hard, I let off and drove another 1/2 mile and accelerated hard again, and another serious buck. Smoke started coming in the cab. I pulled over and got the fire extinguisher and opened the hood. The main engine wiring harness was hot and the insulation melted. I disconnected the ground on the battery and let things cool down again. Drove it 4 miles back home. So, now I need some help diagnosing the cause. Should I start another thread about the melted wiring harness?
