Need more power!
half cab
Guru Bronco
Lose 50 LB's that should make for good tween 2nd n 3rd.
bax
bax
Old Member
Take the winch off the front?
going to 6.17 gears might be the ticket. I run 5.13 now. just looked at the gear calculators and that helps the rpm range up to 60mph
Advance the cam and bring the power band in a little earlier.
water inject and advance the timing.
68stang73
I'm a fan of the 351w. But adjusting the timing might help your low to mid a bit. Bump it up 4 degrees initial but keep your total the same.
broncosbybart
Another vote for some tuning.
I wouldn't run a bigger gear. The pinions get really small. Not sure if you're running a C4. I'm not very happy with the gearing in mine but alternatives are costly and take work.
Losing weight isn't a bad idea either. Yogurt, exercise, alum beadlocks, blingy parts, you know.
Are you going to be racing on dirt or pavement? The stock 5.0 isn't a rocket but it moves the EB just about as fast as I can manage it in the dirt.
There is always this. 500hp for a mere 17k :)
http://www.brothersperformance.com/...-engine.html?gclid=CPvCtJXrhs0CFUgkhgodinALjQ
broncosbybart
Maybe, just maybe...
