Great you found a good combo T-7. Feels good I bet!
The little bit of popping might have a secondary (or maybe it's the primary) reason other than the muffler design. The two that had more popping on decel could also be indicating they're better flowing as well, which is leaning out your fuel/air mixture.
I've forgotten already if you're running a carb or EFI, but if a carb you may just be running a tad lean. You could "test" this (if you can call this a legit test) by plugging up your PCV valve just temporarily for a short drive. If the popping is reduced or goes away completely, you've probably found that your mixture is a bit lean now. If no change, then maybe it's just that this type of muffler is prone to that effect.
It sounds like you kind of like the popping, so it's not a priority to get rid of. But if it's doing it from being too lean you might as well know it so you can deal with it and make certain that the condition does not cause future problems with the engine.
