I'm not going to go out and lay in the snow to take a picture. I used the AA 3550 cross member but moved it backward untill it was under the Tcase to Klune bracket that was supplied with the klune. I added a 4 x.25 x what ever length flat stock to the crossmember on each side where it bolts to the frame then drilled so that the crossmember still bolted up using the stock crossmember to frame mounting holes. Then add one more bolt further back making a total of 5 bolts on each side to mount crossmember. I reused the AA 3550 ruber cross mumber mount under the Klune to Tcase mounting bracket. It all works great and have had no problems.
