Need some Axle and Drum brake part numbers
luderchris
SouthEast PA
I pulled my rear axles apart and need to replace the axle seals and wheel bearings. I also need an adjuster spring for the drum brake.
Can someone help me with part numbers? I did a search and didn't come up with anything.
I have the 28 spline, small bearing axles.
This is the only thing that I can find online that I think would work.
BCA/NATIONAL Part # RA313 {Bearing/Oil Seal Kit}
Rear Axle; Ford 9" R.G.
Thanks in advance for the help.
Chris
needabronco
Prescott/Farmington
Bearings and seals should just be for any small bearing 9", and a generic drum brake spring kit should work for the springs. I suggest you go to NAPA or other old school parts store, unless you know the actual part number the Autozone, or O'reilley's stores are worthless. But what your asking for is nothing out of the ordinary even for them, but they will want to know if it has AC, Power steering, and a AM radio before they can look up the axle seals...
luderchris
luderchris
SouthEast PA
Well -- with browsing around the RockAuto parts site, I think I got everything. Here is what I came up with. Like I said, I have the small bearing, 28 spline axles.
Does this look right?
Wheel axle seal and Bearing parts
1973 FORD BRONCO WAGON
Brake/Wheel Hub : Brake Bleeder
DORMAN Part # 13901 {Bleeder Screw Dimensions 3/8"-24 x 1-1/4" long #1666493, 3780788, 4126879, 4636591, 5455122, 556508J, 8M-2208, 8M-2208-A, E6DZ 2208-A, F0DZ 2208-A, F2UZ 2208-B, J3203313, J3210802, J8124560, J8129722}Rear; w/10" Drum Brakes
$3.02
Brake/Wheel Hub : Wheel Bearing
BCA/NATIONAL Part # RW207CCRA {Ball Bearing Bore=1.3775" Outer Diameter=2.8346" Width=0.8449" Inner Race Radius=0.14"}Rear Wheel; 9" R.G.; 2,750 lb. Axle
$20.99
Brake/Wheel Hub : Wheel Seal
BCA/NATIONAL Part # 9568 {Oil Seal / Nitrile / Shaft Size=1.365" Housing Bore=2.374" Outer Diameter=2.379" Width=0.435"}Rear Wheel; 9" R.G.; 2,750 lb. Axle
$7.76
Brake/Wheel Hub : Brake Shoe
RAYBESTOS Part # 169PG {10.00 X 2.50 Professional Grade #169NR}Rear; 10" X 2-1/2" Brakes
$24.79
Brake/Wheel Hub : Drum Brake Hardware Kit
RAYBESTOS Part # H7143 {Professional Grade}Rear; 10" Brakes
$7.40
Brake/Wheel Hub : Return Spring
DORMAN Part # HW386 {First Stop}Rear; 10"x 2-1/2"; Spring Set: FMSI No.393/78* Non-stock item--shipping delayed up to 2 business days
$3.93
broncnaz
Looks ok but I dont have a parts book to verify any of that. The key in getting the correct parts is knowing what your axle is rated for ie 2750 and what size your brakes are. Those 2 factors will get you the correct parts from most parts stores.
needabronco
Prescott/Farmington
I think a parts house could easily beat those prices, and while your going through all that trouble, why not replace the wheel cylinders while it's apart and just start fresh?
BTW I've never been successful looking up correct part numbers at rockauto.com. I usually look up at napaonline, then crossreference to see if autozone or oreilley's is any different, but prefer napa stuff generally...
luderchris
luderchris
SouthEast PA
I have the small bearing, 28 spline axles -- isn't that the 2,750 lb rating? Can anyone verify?
I didn't buy the parts at RockAuto -- I got them from a local parts place. The prices were similar though.
Napa seems way overpriced most times I check.
broncnaz
There are pretty much only 2 axle ratings 2780 or 3300 lb. with small bearings and 10 in brakes you have the 2780 lb axle.
NAPA's online prices are usually higher than what you pay at the store. Also if you shop there regularly you can usually get a even better price break although it depends on who I talk to at the counter.
