Neg Caster???
Flash69
Southwest Va
Quick Question, When i gas my bronco it feels like my front wheels are on ice. Is that neg caster. It has a 3 1/2 lift. I put new bushings in the radius arms to correct for the lift and i also put Duffs radius arm drop brackets. Im thinking i have over corrected.Any help is appreciated. Thanks..Flash
TexasBronco
Waterford, MI
By chance are you running a super flexy rear suspension and have a hard top and roll bar in. If so the weight transfer to the rear of the truck could cause the contact pad of the front tires to be very small and give little control as if on ice. You may also get the camber checked. If it is still set at factory and you degreed the axle housing and dropped the arms, the way your tires contact the road may be giving you some trouble. The problem sounds bad, but the solution should be easy. Check the camber, and if all right, replace the bushings with stock or less degreed ones.....then if the problem is still there your problem may be something else
rustbucket
Take your Bronco to an alignment shop and see what the readings are. That needs to be done after installing a lift anyway.
SaddleUp
Vancouver, WA
It sounds like the toe in might be off. Another thing to look at is the rear spring u-bolts. If they are loose then the back of the truck will squat down further on acceleration and make the front light. If you added too much castor then it would make it hard to turn the wheels at slow speeds but it shouldn't cause it to feel like it is floating under acceleration.
Flash69
Flash69
Southwest Va
Neg Caster
Thanks guys, The reason i havnt had the thing aligned yet is i have a d44 to put in it and i dont have it built up yet.It drives real good except when i gas it.I do have the hard top on it.I am going to put the rear of my radius arms back to factory and see if that helps and then take it to the alignment shop. I will save the d44 for a winter project.Thanks Flash......I guess i shouldnt be so cheap and go get it aligned huh
