- Jul 31, 2001
- 8,905
I have never done this...check wtrpump by testing pressure in block behind the t-stat with engine up to temp with t-stat open...
Long story shortened...can't quite keep the 418 stroker cool with a copper 31x19 radiator so I called Ron Davis and talked to the tech dept and explained everything about my engine, related items (long story part)... it is a Exploder serp/front dress and a Ford wtrpump
He said to check the pressure in the block by connecting a gauge just behind the t-stat so I am reading pressure in the block with the t-stat closed and open and test at 2200 rpm. He told me 14# pressure in the block with the t-stat open. Without that pressure the water isn't pressing against the block to ensure adequate heat transfer. I had 3 psi. Ron Davis tech said I have a bad pump because he said everything I have should keep it cool...
