So I made a couple calls today...one to Stewart and talked pumps with their engineer and also with Hayden fan tech dept.
Stewart backed up the water pressure block test at least enough to say that the higher pressure aids in heat saturation of the water and increased flow rates and it helps alot in cooling... several of their higher stage pumps do NOT have heater hose outlet fitting built into it therefore if you like heat in your car this may not be the waterpump for you.
Hayden tech...I was discussing their "duty" classifications of their fan clutches and the Exploder one in particular since that's what I'm still using. We discussed my high rpm heat build issue and he had some interesting theories behind no cooling issues at low speed but when really pushing my engines limits at 5K rpm, I can push 220 in 5 minutes when pushing snow with my front bumper at 20def F.
He suggested the fan might be operating at only 15% rpm due to safety features built into the fan to keep it from self-destructing...and I said WHAT? Due to safety issues OE clutches will protect themselves from destruction by disengaging at higher rpm and suggested this might be part of my "only overheats when under severe load usually only coupled with 5,000rpm use for several continuous minutes. Interesting theory... He suggested using a mechanical fan instead of a clutch fan...
Never heard of this before..anybody else back this up?
