    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
New 1970 Bronco for sale
Status
Not open for further replies.
davidm
Pa
Here is the nicest Bronco on the planet for sale. Everything is New or completely rebuilt with all new parts.
A total frame off rebuild.
The frame has been walnut shell blasted, every seam and joint welded and then the frame was completely boxed. The frame was then powder coated in gloss black. 5 steel 15'' bead lock rims, with 33x12.50R15 Mickey Thompson Baja Claw tires. 4 wheel power disc brakes with braided brake hoses and new stainless hard lines from the master cylinder to every wheel. All nuts and bolts are stainless grade 8. Every steel part has been powder coated. A new Dana 30 front rear with new axles, Lock-Right Locker and 5.38 gears. A new 9" rear with new axles and a Detroit Locker with 5.38 gears. New Warn locking hubs. Both rears have been totally powder coated. All new steering components TRW links, ends, U-joints. New rock crawler power steering kit, box and pump and all brackets powder coated. Wild Horses Suspension 5.5" rock crawler kit includes, front springs, rear leaf springs, powder coated front and rear shock hoops with 6 Rancho RS 9000 adjustable shocks, 2 at each wheel and new powder coated radius arms. 2 new drive shafts, completely rebuilt Dana 20 Transfer case and a rebuilt NP 435 transmission, Centerforce dual disc clutch kit, powder coated trans cross member with new mounts.
351W .30 over TRW forged pistons, complete rebuilt engine by H G Associates Inc all ARP hardware inside and outside of engine, ported heads roller rockers and an off road RV cam, 650 Holley carb with electric choke, we jet hot coated the intake, water pump, valve covers. Jet hot coated Hooker headers with a complete stainless exhaust system including a pair of stainless Borla mufflers. Holley electric fuel pump, adjustable regulator, braided hoses and new lines from the new fuel tank with a custom powder coated fuel tank skid plate cover. New starter, one wire Mean Green HO alternator, MSD 6Al ingintion box with a new Billet MSD distributor. A complete new wiring harness feeds the electrical system along with a custom dash mounted fuse panel that feeds into twin rear mounted Optima batteries mounted in 2 boat battery boxes. Aluminum drive pulleys with new belts. Aluminum racing radiator with a Spal 16" electric cooling fan. Custom dash with the full range of Autometer gauges. Moon gas pedal. Grant steering wheel. 3 Corbeau racing bucket seats with 5 point Simpson harnesses, mounted to the custom built powder coated roll cage. This cage is fully removable from the body, it is attached to the body and frame using all grade 8 stainless hardware. This cage was custom built to the owners specs. We added custom side steps that also attach to the interior cage and frame. The Extream fiberglass body kit has been Rino coated before the PPG white paint was applied top and bottom of the body. The interior has been finish with powder coated side panels and half doors. The body has high arched wheel wells with flairs and a raised cowl hood. The front Pre-runner winch bumper has also been powder coated and a Warn HS9500i winch has been mounted using stainless hardware. 2 KC Highlights mounted high on the bumper. The rear Pre-runner bumper has also been powder coated and a custom rear spare tire mount and high lift jack were attached to the bumper. The rear seat has a mounted storage safe. The center console is a Tuffy 10" deluxe storage box.
We have all the receipts from the build with part numbers for any parts that may need to be replaced in the future.
You will not find a nicer Bronco anywhere. I have 65 pictures to show ever part of the Bronco
Rob1962
Ya think for a $75k bronco, a picture might be a good idea?
FRANKO289
Bronco enthusiast
would luv to see what a EB looks like when stackracing gets done with it !!
needabronco
Prescott/Farmington
Do you mean to tell me my Bronco didn't come with a boxed frame?%) Maybe every single Bronco I've ever seen has the same custom boxed frame as yours?:-X
$75K and a dana 30 without any pix is REAL hard to swallow. Not bashing just saying. It's hard to sell a $5k Bronco without pix..... If your asking that much pony up the $12 and become a contributor.............
D
davidm
Pa
Every seam of the frame was welded shut and then coated.
FRANKO289
Bronco enthusiast
The 3 pics i received from Stack Racing ...
D
davidm
Pa
Pics
Hi Guys
What do I have to do to be able to post the pics here?
needabronco
Prescott/Farmington
Are you sure you aren't asking; seven thousand five hundred, or do you really want sevety five thousand? Again, I'm not bashing your sale, I'm just clarifying that the price isn't a typo?
To Post pic's you need to become a contributor. Look in the upper right hand corner go to User CP, then scroll down to paid subscriptions and follow the link. Good luck.
FRANKO289
Bronco enthusiast
add pics !!!! luv that clean eng. bay !!!
D
davidm
Pa
Pics
Here are some pictures of the 75K Bronco
D
davidm
Pa
More pics
So how does it look so far?
D
davidm
Pa
Even More pics
Well is it worth the money or what.....
D
davidm
Pa
Heres more
You asked for them here they are
Heus33
Its very, very nice, but frankly, no, its not worth $75,000. I'd have a hard time saying it was worth more than $20,000.
Good luck with your sale.
Status
Similar threads
