Hi all, looking for assistance. I'm in the process of swapping out a freshly built D44 for my old Dana-30. From the 30 I'm carrying over everything from the spindle on out including; GM disc brake conversion, rotor, hub, bearings, lockout, etc.
The problem I'm having is with the lockout. I'm using Warn premium lock out hubs. My old D30 had a bolt and washer that installed right into the end of stub shaft and essentially holds the entire locking hub in place. My new D44 cromo stub shafts have no hole for this bolt.
The Warn hubs also have 2 snap rings, one small one on the end of the axle, and one large one that locks into the outer hub. Do I simply omit this locking bolt with the D44 setup and rely on the 2 snap rings to hold the lockout onto the hub? Or do I need a different lockout hub kit for this D44 axle?
