LittleBeefy
Huge Brakes - www.hugebrakes.com
- Joined
- Aug 1, 2023
- Messages
- 67
Proportioning valve is a terrible name because, unlike most things on a car, the name doesn't actually match what they do. I like to think of it as a pressure dampening valve. It is essentially there to allow brake bias to move more towards the front under heavy braking conditions to account for the fact that the front of the vehicle is being pushed down and the rear of the vehicle is being lifted up as the center of gravity tries to work its way over the front axle. I'm going to explain with very simple numbers to illustrate. Ignore my numbers above for now. Let's say that you have a 50/50 bias on paper (because you are a 96 F450 Super Duty and you have the same brakes on the front and the rear) and that you have a proportioning valve with a 50% reduction and it's set at 500PSI. If you press your brakes to the point that you get the PSI inside your calipers (both front and rear) to 400PSI, your proportioning valve is doing nothing and your brake bias is still 50/50. Now brake harder, let's say to 500PSI (just at the threshold that the proportioning valve is going to kick in); you will still have 50/50 bias. Now brake harder to the point that the front brakes have 600PSI. The rear brakes will now get reduced marginal pressure caused by the prop valve limiting the rear increased pressure by 50%, thus they will have only 550PSI (50% of the 100PSI that is over the 500PSI threshold) and the bias will be ~52/48 (600/1150 front and 550/1150 rear). Quick note, the only reason I can do the math on bias with just the caliper PSI is because the front and rear brakes are assumed to be identical so the bias is directly proportional to the caliper pressure. Moving on, let's brake harder, increasing the pressure in the front calipers to 700PSI. Now the backs have 600PSI and the bias is now~54/46. Now press the brakes with Iron Man's suit on so you raise the front caliper pressure to 1200PSI. The rears will now be at 850PSI and the bias will be ~58/42. I think you are getting the gist. The prop valve causes the bias to shift forward as you brake harder (over a given set threshold in the prop valve).
The "proportioning" comes from the fact that the increased force of your foot on the brake pedal has to go somewhere, and since the rear brakes will take less of an increase in pressure than the front, it must be sending that increased pressure to the front. I'm just accounting for that fact in that I'm measuring the resulting total pressure at the front first, and then deriving the pressure at the rear.
If you want to look at your particular case, your prop valve has infinite settings and a 57% reduction. I'll imagine you set your prop valve to kick in at 550PSI (which is reasonable) and you are using Eldo rears with FF pads front and back. Up to this point you will get the most bias to the back.
Press the brakes harder and harder:
You can see how the bias would shift forward in your specific case. Set the threshold lower and the bias will start shifting sooner. The idea is to set the threshold just to the point that the tires in the front lock first.
| Brakes | Rotor Size | Piston Size | Piston Count | Piston SA | Distance of piston center from edge of rotor | Piston CoF Distance | Caliper PSI | Clamping Force | mu | Braking Force | Braking Torque (lb*ft) | Bias Rear | Bias Front |
| Fronts (FF pads) | 12.95 | 2.2 | 2 | 7.60 | 1.100 | 5.3765 | 550 | 4181 | 0.4 | 3345 | 1499 | ||
| Eldo rears (FF pads) | 12.50 | 2.5 | 1 | 4.91 | 1.250 | 5 | 550 | 2700 | 0.4 | 2160 | 900 | 37.5% | 62.5% |
| Fronts (FF pads) | 12.95 | 2.2 | 2 | 7.60 | 1.100 | 5.3765 | 700 | 5322 | 0.4 | 4257 | 1908 | ||
| Eldo rears (FF pads) | 12.50 | 2.5 | 1 | 4.91 | 1.250 | 5 | 635.5 | 3120 | 0.4 | 2496 | 1040 | 35.3% | 64.7% |
| Fronts (FF pads) | 12.95 | 2.2 | 2 | 7.60 | 1.100 | 5.3765 | 850 | 6462 | 0.4 | 5170 | 2316 | ||
| Eldo rears (FF pads) | 12.50 | 2.5 | 1 | 4.91 | 1.250 | 5 | 721 | 3539 | 0.4 | 2831 | 1180 | 33.7% | 66.3% |
| Fronts (FF pads) | 12.95 | 2.2 | 2 | 7.60 | 1.100 | 5.3765 | 1000 | 7603 | 0.4 | 6082 | 2725 | ||
| Eldo rears (FF pads) | 12.50 | 2.5 | 1 | 4.91 | 1.250 | 5 | 806.5 | 3959 | 0.4 | 3167 | 1320 | 32.6% | 67.4% |
| Fronts (FF pads) | 12.95 | 2.2 | 2 | 7.60 | 1.100 | 5.3765 | 1150 | 8743 | 0.4 | 6994 | 3134 | ||
| Eldo rears (FF pads) | 12.50 | 2.5 | 1 | 4.91 | 1.250 | 5 | 892 | 4379 | 0.4 | 3503 | 1460 | 31.8% | 68.2% |
