New bronco, different fuel setup..
guidoverduci
NorCal
Hello-
I'm going through my bronco and I'd like to redo the fuel system that the PO has going on. First, it's a 351W from an '89 pickup and I'm assuming did not have a mechanical pump cause I don't see a plate where the pump would be. It also has an edelbrock carb. The current setup is an electric holley fuel pump for each tank through a filter, then to the engine bay where it goes through what looks like a regulator then one of those clear filters, then carb. I will say.. it fires right up and runs great.. but I'm thinking of simplifying it a bit and also removing the aux tank. It also has an O2 sensor in the exhaust hooked to an analog Air/Fuel mixture gauge. Here's some questions...
1. Should I run a filter before the fuel pump?
2. Is there a quieter electric pump for carbs?
3. If I run another filter right after the pump, can I ditch the clear one in the engine bay?
4. Any suggestions on filter size for this setup before / after the pump?
4. Do I need that regulator, or whatever it is?
5. I'm assuming the air/fuel gauge is just for simplifying tuning the carb, but is it necessary? I'm replacing the exhaust and not sure if I will install it on the new exhaust.
6. Or.. should I not touch anything since it fires right up.... ;D
gr8scott
1. Always.
3. Probably.
6. Why fix something that isn't broken?
surfer-b
4: depends on how much pressure those pumps are putting out and how much is needed at your carb or whatever you are going to use
6: if it runs good and fires up no problems I would leave well enough alone
freemanrebel
Sounds like a bad ass system. You have two pumps for redundancy. If you fuel pump fails on either tank you can simply switch to the other tank. Assuming it has fuel.
G
guidoverduci
NorCal
Sounds good y’all. I think I’ll keep it. Anyone care to comment on the 02 sensor with the analog air/fuel mixture gauge? I’m replacing the exhaust, should I reinstall something similar? Perhaps update to a digital gauge? It’s just there to help with carb adjustment, correct? The goal would be to have the right AFR at idle?.. adjust till gauge reads good?
