New Bronco Owner - Almost
Schloer2
Schloer2
After driving it all day I realize that I am gonna need to do some trans work. The C4 likes to stick a bit before engaging.
Hmm, maybe just needs a long overdue service? I assume the trans fluid is up to the level, but maybe it's very old and you just need a new filter and fluid change.
Here's to hoping anyway. Might be one of the reasons they were glad to get rid of it, but at least the C4 isn't some exotic mix of unobtanium and munimula. So it shouldn't take too much to get it up to snuff.
Great rig. '76 was a good year, and if you haven't found rust by now, you're gold.
I notice that they used the old "light" Ford Blue for the engine paint, but that at least shows that they did have things apart for some servicing. Does it run like it was rebuilt? Smooth and quiet and torquey?
Schloer2
Schloer2
Engine is actually a rebuilt 351 that was installed ~1 year ago. It fires and runs like a dream. Also, no real rust uncovered after crawling all over it. The trans is the only thing that I have noticed that will need some attention.
I can see it now... They spent a wad on a nice rebuild and then all the extra torque put the old transmission on notice.
Once it started acting up, the frustration just got the better of them and they sold it.
Wouldn't be the first time that happened with a project.
half cab
Guru Bronco
Maybe like Paul said "just needs service"...we'll hope anyway...still a great buy even if you have to spend some on the trans!!...in my op.
Schloer2
Schloer2
Hopefully just service...but won't be furious if I have to put a few bucks into the trans...still happy with the buy
WheelHorse
5G is a heluva deal.
Too bad you're four hours away, could use more EB's up in these parts.
Schloer2
Schloer2
I have lived in St Louis for 8 years and have only seen 3 EBs on the road.
Schloer2
Schloer2
Last night I took the Bev (finally named the Bronco) out to pick up some dinner. The C4 seemed to shift just fine all the way to the restaurant and then on the way home the trans slipped out of Drive when I came to a stop at a stop sign on an 25-30% incline. After about 5-10 minutes of shifting through the gears and shifting in and out of 2wd and revving the engine, it finally re-engaged and I was able to drive the rest of the short trip home. I checked the trans fluid and it is above the full (when hot) line so it doesn't just need fluid. I have had issues with it sticking when initially shifting into gear, but never had it fall out of gear or take more than a moment to engage. Any thoughts before I take it to the transmission shop?
surfer-b
Post your Q in the tech section and you will get some hits on it, they may not be following this and not know you have a Q about the tranny.
Fireball05
I don't have a C4 and know nothing about them, but you can also edit the heading of your post and that may get you some more views. I know that is what some folks do on their build thread when they have updates.
Or you can start a new thread as Surfer-B suggested. He's got two awesome Broncos, so he knows what he's talking about! :)
