crutch
- Jul 3, 2015
- 249
I just installed a new Edelbrock performer 289 intake and 500 cfm Edelbrock carb and fuel filter. The engine fires up but won't hold an idle. If I leave the throttle pressed half way down it will continue to run until I let the throttle off or if I push the throttle all the way down it will die.
I have tried to adjust the idle mixture screws and have opened them all the way up but no luck. I made sure the vacuum connections are all hooked up. This is an electric choke which I was playing around with a bit but not real sure how to set it.
Any thoughts on what to test/troubleshoot? Thanks!
