New Clutch having issues.....
stoker
I’m running a 351W coupled to a 4-speed top-loader. Over the winter months I pulled the engine and installed a new rear main seal and new LUK clutch. I’ve only put a couple of hundred miles on it so far this summer. The new clutch was engaging at the bottom of the pedal travel (near the floor) but performing fine. Yesterday, on my way home, I felt the pedal “give” slightly and the clutch would not fully disengage with the pedal hard to the floor. I also had increased free play at the top of pedal travel. I figured it was a linkage issue but could find nothing amiss. I adjusted the pushrod to restore the correct free play in the pedal and everything seemed fine at first but soon went back to not fully disengaging after a few shifts. I can’t figure this one out but it looks like I’ll be pulling the engine again to check the clutch. I’m leaning towards a faulty clutch……..
Anybody have similar issues in the past?
Incidentally, the new rear main seal (1-piece, Fel-Pro 2921) still seems to drip oil but I can’t see this causeing the clutch issue.
blubuckaroo
Grease Monkey
Ridgefield WA
Did you replace an old "Borg & Beck" (three fingered) style with a diaphragm style?
The diaphragm style takes more travel to fully engage and disengage. I had to raise the rubber upper bump stop to accommodate that travel.
Also, if you felt something "give" you might want to check the firewall where the pedal mechanism mounts. I've seen cowl rust that cause that problem.
stoker
stoker
Yes, The new clutch is a diaphragm style. Seemed fine for the first couple of hundered miles though.
I'm pretty sure the rubber bump stop is all the way up already. The clutch pedal sits considerably higher than the brake pedal.
I'll check the pedal mounting arrangement tonight. Thanks.
SHX669
Yes what blubuckaroo said - I had to " mess with " mine a couple of times to get enough travel .
On your rear main seal - did you use sealant on the flywheel to crank shaft bolts ? they can leak there if you didn't
pcf_mark
The clutch pedal is always higher than the brake - the travel is considerably more. Engine off try to turn the driveshaft when someone pushes the clutch in while in gear. If you can't it is not adjusted right yet. Then it is adjusting the free play to get a clean release with it running / high rpm.
When something "gives" I would get concerned. Maybe take the start off and take a peak in to see if the fork or diaphragm springs gave up?
stoker
stoker
I raised the rubber pedal stop all the way which gave me a bit more travel in the pedal. Adjusted the linkage and all seems okay now. I'll give it a run tomorrow and hope it stays as it is. Strange how it was good and then needed further adjustment. I've not seen that happen before.
SSH669, I didn't use sealant on those bolts. Considered it but found them to be blind holes.
Thanks for the replies.
WILDHORSES
USA
A couple of more random yet pretty common issues. I don't know what year Bronco you are dealing with but the early years had a pretty weak equalizer bar they are known to crack and may not fall apart right away. Have someone press the clutch pedal while you are looking at the bracket.
The other thing is that clutch fork pivot attached to the inside of the bell housing. They can come loose. It would be hard to see that issue but you may be able to pull the boot and look inside while pressing the clutch.
I've installed many Luk and Centerforce clutches but have not had them act like what you describe. That leads me to believe it's a related part. I would not take the whole thing apart without checking these items.
Good luck
Jim
blubuckaroo
Grease Monkey
Ridgefield WA
Good luck
Jim
Good point WH, about the loose fork pivot.
From the factory they are riveted to the bell housing. Those rivets can loosen up and cause issues. I haven't had it happen to me, but I've read about it here on CB.
Here's a repair kit for that issue.
https://www.tomsbroncoparts.com/product/tab-style-clutch-fork-pivot
