casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
Is this going to work OK? I'm reconfiguring my fuel lines from the passenger frame rail to the drivers side now that I have changed my exhaust. For about 8 years I have run my EFI without a low pressure pusher pump and without an accumulator. Since I'm moving it anyway I'm considering adding the LP pump and using an accumulator/Filter in place of my current filter. If my thinking is correct, the pusher pump is needed to use an accumulator. All of the setups I have seen that use dual tanks and an accumulator use two low pressure pumps, one for each tank. In the interest of saving a few bucks and saving space, is there any reason I can't use just one low pressure pump by locating it after the 6 way valve? Or perhaps, I should leave the low pressure pump and accumulator out and just move the lines? My Diagram shows a filter not an accumulator but it should convey the idea of what I'm going for. I'm moving the lines because they are now closer than I would like to the exhaust and because it will drastically shorten the length of the fuel lines.
