T-7ToNewOldB
- Dec 7, 2018
- 315
New 347 with Pro-Flo 4. Basically everything is new. Turn ignition and engine fires up smoothly and immediately. However, when I release the starter it dies immediately. No sputtering just off. If I had the starter on it keeps running very smoothly. So something electrical in the ignition system. Set cylinder 1 to 12 degrees BTDC. Confirmed on compression stroke and lined up with measurement on harmonic balancer. Installed distributor per supplemental instructions. (Did this three times so pretty confident.). The estreet software is set up correctly for my 347. (Early bronco) so uses the firing order for a 302HO/351. Fires right up and runs smoothly but the second I stop cranking it dies. I assume this is something to do with the coil. I has power with the ignition in on only so that wiring appears to be correct. Tried a jumper from the batter to the + terminal. Didn’t help. I have a MSD 8202 Blaster 2 Hi-Performance Coil.
Tried a jumper directly from the battery to the positive terminal o the coil. Didn’t help.
Thoughts?
Thoughts?
