Ok...much ti my dismay I have delicately place a new 302 into the comfortable bonnet of my 77.. I had it running like shit fir a minute. Decided to dbl check the timing. TDC. Check. Distributor pnting at #1. Check. Fuel. Check. Spark. Check.
Nothing...can the harmonic balancer move?... Or can the key slip out?
Just to verify, when you say "Distributor pnting at #1. Check", do you mean rotor button pointing at the #1 spark plug location or do you mean the rotor is underneath of the #1 contact in the distributor cap? Of course, the correct way is the latter.
Some folks may laugh at the question, but I ran into this one time. A guy ask me to help him get his BBF running and he had installed the distributor so that the rotor button was literally pointing at the #1 spark plug because that's what he had always heard to do "point the rotor at #1"
As stated, the harmonic balancer can slip on the rubber spacer and cause false readings when using a timing light - probably not possible for the keyway to come out but I guess it could shear off (unlikely but possible)
Can you offer some specific symptoms you are experiencing with the motor - running like sh*t is pretty broad and difficult to diagnose and offer suggestions
DJs74
