I am looking to change my front axle. Right now I have a D44 with good axles, detroit locker and 5.13. I dont have huge HP right now with a stock Coyote. Not really heavy crawling, more higher speed on and off road cruising. Four link rear and coil overs on all four corners. Front right now is Cage arms. The caster angle and pinion angle is all messed up so I for sure need to rotate the outers on it to make it right.
I need to keep the 5x5.5 pattern. Also do not want super heavy. Might change top custom radius arms up front or keep cage arms, dont really want to use wedges and bushings.
Choices I have thought of is to build a new D44 with Solid parts and maybe Crane inners and Reid outers. But this still uses weaker D44 parts.
Maybe a 9 inch front end. Could use D60 outer parts or other.
Mostly want to build one with new parts just to make a project out of it. Unless I could find something good used to cut up and make work. What do all suggest?
