WELL Maybe just a concrete slab.
. DO Any of you Guys get concrete waist from your Concrete provider.
So we have an Ingram Batch Plant Here in our town.
... & When the trucks come back into the plant ... They have to be cleaned out .
SO THE truck backs under a Over head water out let that runs a 4inch stream of water 24/7... The drum is turned & Drove to a dump & there waist is pumped out of the drum . 2 or 3 trips & the inside of the drum is clean.
It sets & settles out & the water runs off the top of the waist . Waist is picked up with 3 yard loaders & piled & more water drains out of it. They keep working the waist until it's just about dry material like chalice .
... SO Our plant is so big they can't get rid of the waist . So they give it away.
I get it & put it on my drive way. Other than being dusty. It's great stuff after it sets up.
........ NOW have any of you used this before. I'm ABOUT TO build a parking spot for 5 or 6 farm trucks . I'm thinking about putting down a layer of black plastic . * I've got a lot of old waist rebar. & I'm planning on bringing in about 12 of 15 loads of waist & PUTTING It about 4 inches deep . I'm going to smooth it out flat maybe with my tractor then rake it . & Turn the sprinkle on it. This parking lot will just be above the house & In the edge of the pasture . I've got 9 farm vehicles .. So I'm trying to get the away from the house some what. If their in the barns ... The rats get in them & chew them up. My Trees around the house are stopping up the heaters . So I need a new parking lot.
....DO YOU THINK THIS WILL WORK.
.. I do have it on my drive way. & Even Meme likes it.
... Now I need a Dump TRUCK. Should I tell MEME I've found one .
1978 Chevy 1 ton dually & a dump bed .454 4 speed .TITLE & ONLY $1500.00...
....... & IF I great good flat spot I can park my 2 & 3 Broncos closer to the shop . Snake Bite, my CAMO Bronco, needs back in the Shop .
