New owner from Germany
T
tody
new fender apron is here. took less than two weeks to arrive. thanks to the ebay international shipping program, which works like a charm.
so i cut the old fender apron out:
the upper corner of the radiator support had two layers, not welded together:
this what was left:
started fitting the new piece:
this area had no spot welds, instead the front seam was welded in some places. a lot of grinding and straightening to do:
started to clamp everything in place:
and this is why you shouldn't start digging deeper into your bronco. look how much i had to cut out :cool:
i'll start welding in the new pieces soon!
sprdv1
REBEL
It rainy and dreary in Germany this time of year...so it's a good time for this sort of thing. You'll get it knocked out quicker than a lot of folks do.
I miss the Germany days, 87/88, mosel river, wine fests... Oktoberfest.. Good times
T
tody
ok, here we go again - welded in some panels today.
first on the passenger side, where i tied in the fender apron to the kick panel with one single piece, instead of the two overlapping panels:
in the bottom corner of the kick panel, i need to patch in a small piece:
on the driver side, i welded in the replacement panel. there's quite some tension on it. the core support is bent along the bottom, and it took some time to align everything:
here's a gap i need to close. i don't want to put in a piece as big as before, so maybe i'll just patch it along the bottom:
more to come (hopefully) next weekend.
T
tody
what a difference a coat of black paint makes...
all pieces welded in, first coat of paint, seam sealer applied.
started fitting the firewall insulation.
top piece went in really well, minor trimming required.
the firewall piece also fits really well, contrary to what I read on here.
one hole for the fastener is out of whack, but the rest lines up fairly good.
see the last picture? the fasteners are actually threaded on the inside. put a 5/16 bolt in there, and push the whole thing trough the hole in the firewall. then unscrew the bolt. made the installation a breeze, suddenly it's only a one man job!
T
tody
well, it looks like i might have a lot of time on my hands to work on the bronco. life is slowing down rapidly here in europe.
all schools will be closed beginning on monday, for now right until after the easter holidays. that's five weeeks.
i'm self employed, but i doubt that there will be that much work in the next few weeks.
went to the garage yesterday, but forgot to take pictures. here are some of how the bronco sits today.
fixed the passenger side vent. discovered a 2k superglue, cyanoacrylate with some kind of powder/garnules, which makes it easy to bridge gaps in the plastic.
put it in. i am aware that it is only screwed in on the kick panel, but it had two screws in the top portion. put them back in, but with seam sealer underneath.
had to get a little creative to get the heater box back in place:
but i managed to fix the air duct. removed the replacement from my shopping list:
also put the pedals back in, all blasted and painted:
got a big box of fasteners, and started putting the fenders back on:
but that's going to be a nightmare to align...
will need to get out the welder one last time. need to fix two openings for the j-nuts, one on the front grill and one on the driver side fender. and on the windshield frame. i now believe that this is the area where the water came in in the first place. if had fixed that first, i wouldn't have ripped apart everything :cool:
74BroncoCO
I commend you again on what you are doing. Restoring one of these in their native land is an undertaking for the hobbits. Tackling this from Germany adds a whole new level of commitment! You will be sporting a sweet and unique rig when you're done!
bronkenn
Bronco Guy
Southeast Ohio
Nice job Tody. I think if you loosen the bolts holding the core support to the frame and pry the core support to the right, it might help the hood to fender fit.
T
tody
that's a good idea. the driver side is already loose, as i had to make the fender apron fit.
the fender on the driver side is another problem in itself. the small lip going over the fender apron is not fitting well in the middle. might have to persuade the fender in place anyway.
T
tody
another step forward.
grille is back in. loosened the complete front end, even moved the hood a little to the passenger side. on the passenger side, the hood sits a quarter inch too short. here is how it looks now:
the previous owner did not use shims on the hood, but bent the driver side hinge. the whole thing will give me lots to play with, but i'll hang the doors back on first and work from there.
i also took home a little puzzle. i know these can be bought new. but consider shipping and taxes - i think i save over $150 by glueing it back together. still need to fill the gaps with epoxy and remove all the silicone it was held together with before:
svastano
Pulaski, PA
JB weld would also hold it together. I would use a small die grinder in the cracks to get a bit of depth to them and then use the JB weld ( epoxy) to fill them back in. Sand smooth and then re-paint black.
T
tody
well, i installed the vent box, and i swear, i closed the hood very slowly and carefully. still adjusted too low, and one of the corner pieces broke off again. glued it back in, removed the top seal, and will adjust the hood accordingly before closing it again.
on a lighter note: my windshield - see above - arrived today. my buddy picked up his mustang two weeks ago, and handed over the windshield today. it arrived in one piece, and $110 shipped through amazon ain't too bad a price!
T
tody
painted my dash today. tried to be very careful, as i had no experience with 2k paint (from a can, in this case). slightly better than the rattle can paint that was on there before, but far from good. still, i gained experience from this!
T
tody
and just like that the dash is back together. not completely, but for the most part of it:
T
tody
fixed the windshield frame today. it was cracked in the lower passenger side corner. as far as the lip goes, it possibly was never welded in that corner from the factory. clamped it down and welded that, too. the lip was spread apart in this area, also spreading the seal - leading to a massive leak. hope that's fixed now...
also further connected everything under the dash. two questions remain:
  • how do i get the little firewall seal over the speedo cable?
  • and what's the best way to put in the column with a new seal? i guess i will need to disassemble the column to slide the seal on, because of the lower shifter brackets. but what about the firewall insulation? don't really want to cut it. what about sliding in the column and reassemble it in place?
oh, and finally - i need to decide on what to do with my dashpad. it had a cap on it, but that didn't fit very well. will remove all the silicone inside, but it does not want to go on all the way. do they really fit that bad? might get it reupholstered instead.
