What I said about it being pretty easy to turn once the wheels are off the ground might be more true of the 6-turn boxes than the 4-turn models, but I'm pretty sure I've played with both and did not have to struggle to turn them with either one.
the steering shaft is odd, though. it has the manual steering bell assembly, but also a coupler (u-joint) in the middle. it seems that the shaft has been modified with the coupler for better geometry. but the manual bell end must be the wrong size, 3/4" 36 spline, somehow fit onto the box which should be 13/36" 36 spline, right?
Yes, the factory power steering was an odd duck. Not sure if the conversion boxes (changed from a 6-turn to a 4-turn) use a different size still, but the factory one at 13/16ths was different from most.
Most later model factory boxes were the same 3/4 x 36 of the manual box.
is it possible to do that? it's only 1/16" of a difference, so i assume with some persuasion this is actually possible?
Yes, I've tried it and it's surprisingly easy. I don't know how safe it is, and I've never driven one like that, but it's easy to see how someone might think they're the same size and not think twice about it.
so what to do to replace just the box?
Much easier to get a proper u-joint/yoke with the proper sizing I would think.
Borgeson and Flaming River both have 13/16 x 3/4DD joints that can be used as "adapters" to a standard lower shaft. Assuming you have enough length in your already custom setup.
Are there pictures of this earlier in this thread?
i wrote TBP an email asking for the box i put a link to in the above post.
if the manual shaft was fit on the old box, it should fit this one also?
Possibly, but it's a relatively new box to me, so I don't know which size input shaft theirs uses.
Heck, even the typical aftermarket conversion boxes like we carry have not kept the same input size all along. I can think of at least four different changes that they made over the last 7 or 8 years.
on the other hand, i found their complete borgeson kit on ebay for a fairly reasonable price, including the pump and new steering shafts.
so this would also be an option, but with customs and taxes probably double the price.
The boxes are very heavy as you know.
so - what to do?
just make the box i have now sloppy as it was before? ;D
Not necessarily. There may still be a mid-way point that is a happy medium. Have you tried adjusting the preload screw back out a little?
Say start at just 1/8 turn counter-clockwise and drive it again. If no change, try another 1/8 turn.
I would not go more than 1/2 turn total though, before putting it back where it was. If it has not reacted positively by a full half a turn, there may be other issues.
But don't forget to try the correct adjustment checks first, rather than just guessing.
Naturally just loosening the screw a tiny bit is the easiest way to go. But it doesn't give you repeatable results if needed either.
Still a few options at least.
