G's Baja Bronco
going to order some 1" 1/2-20 lug-nuts, I always like how they look on baja racers!
Where did you get the adapters to the mustang proportion valve? Do you know the sizes?
I need to either get ones that go into the master cylinder or to the prop valve like you did. I think you are supposed to use the bronco prop valve if you are running drum brakes on the rear and the mustang prop valve is used when you have disc front and rear. Not sure on that though.
G, Nice work man! It is comin along for sure. Just skimmed through again and great job!!!! ;D
