crutch
- Jul 3, 2015
- 249
I just installed a new saginaw power steering pump (from WildHorses) with a rebuilt power steering box and I've got no power steering. I was reading a post about possibly the pressure valve in the pump being stuck.
Should I start with checking that pressure valve? How do I reset that? Is there a particular type of fitting to use on this pump? I'm using an Aluminum -6AN AN6 Male Flare to 5/8 x 18 Male Thread Inverted Seat Adaptor Fittings Male Inv Flare Connector. I do have the Lee fitting that I used on the Explorer pump. Fitting, Straight, AN flare to Metric, Steel, inverted flare, -6 AN to 16mm x 1.5 Male Washer, Aluminum.
Thanks!
Thanks!
