So my new speedo head reads high and low, this is so baffling to me. When going 30(by gps) it reads low around 22 or so and when going 65 (by gps) it reads 80. When going 50 (by gps) it reads the correct speed traveling.
So far I have installed;
A new speedo head
A new slightly longer speedo cable routed very smoothly
Tightened the yoke nut to spec
Checked the drive gear and it doesn’t appear to be spinning on output shaft.
I have an 18 tooth driven gear (yellow)
I have a white plastic driven gear (I assume the white means 6 tooth)
I have what I think are 4:11 gears with 33 inch tires.
What would cause the speedo to read high and low? Is this a calibration issue? I thought a brand new head from our vendors would come calibrated correctly and I would only have to change the driven gear for larger tires.
Thank you for your thoughts and time!
Zen
A new speedo head
Zen
