Speedo gear size?
Depends on the number of teeth on the output shaft. Viperwolf has a nice chart that has been reposted maybe 100 times that gives the driven gear for different tire and axle sizes for both of the common driving gear options. But without knowing the driving gear tooth count, can't give a driven tooth count. What works for someone else won't work for you if the driven tooth count is different.
