new third member yoke question
m_m70
Prescott AZ
going to buy an assembled third member from one of our vendors but it doesn't come with the yoke. Quick question is when putting the yoke on the shaft does it get torqued or does it have to be set up with the nut that holds the yoke on??
Mike
Strange that it wouldn't come with a yoke. To me that's an integral part of the setup.
But then I'm no expert either. Subscribed anyway to hear what the experts say.
And yes to the torque and yes to the nut. You torque the nut down on the yoke as part of the assembly. Either on a crush-sleeve, or a solid sleeve collar that's coming back into vogue it seems.
ENDLIFE
Some third members don't come with a yoke simply due to the variations in u-joint size, and it's simple to set up once you have the proper yoke. What some vendors will do is set up their third members with a solid preload spacer. The solid spacer will allow you to throw on your yoke and simply torque to spec. If they send you a third member with a crush sleeve and no yoke, I would highly question their standards as a drivetrain builder.
