New to me 351W
recoiljunky
Dothan, AL. USA
I friend just gave me a 351W. He stated that it was running when pulled but then he pulled the heads off to start a project. The project got sidelined, so I got the motor.
The block's casting number: D4AE 6015 AA 7, then it has a tag that says 4H7.
The heads are 351 75. I assume they were made in 1975.
I've got the motor partially torn down. I need a puller to remove the damper. I'm planning on carrying the block and heads to a local machine shop to have them clean, inspect and rebuild.
I'm wanting to build a 393 stroker out of this. I'd like to keep the stock heads for $ purposes, throw in a RV cam with new lifters, and install a 4 barrel intake and carb.
Am I wasting my time with these heads?
Which cam, intake and carb? I'm thinking Edelbrock cam and Performer intake and a 650 Holley TA.
Any other thoughts? I won't take offense to negative comments, I'm new to this and could use the advice.
Edited for the update:
Damn, this project snowballed. Scat crank, Keith Black pistons, Crane cam, roller rockers and timing gears, Edelbrock heads, Edelbrock intake, Holley 670 TA, ARP bolts, blah, blah blah....
I'm waiting on the arrival of my Super-Cool-Over-The-Frame-Custom Headers. I also need to finish piecing together my Explorer Serpentine setup (if anyone has an Exp Serp set up let me know.)
Buy the Centerforce II clutch, throw it all together and presto, a drive line destructing monster is born.
It's going in my topless, 36" TSL wearing, spool / fool driven '75.
Edited for update 12/5/08:
IT'S ALIVE!
After taking a whole lot more money and time than I had anticipated, my 398 Stroker is running.
I waited until 8:30 this morning, after the neighbors went to work and tried out the new motor. It fired up with little more than a bump of the starter. I let it roar at 2000 - 2500 rpm for 30 minutes. Temp stayed around 190, oil pressure was around 55 psi.
I couldn't help but blip the throttle a few times. This thing raps! I haven't got any exhaust on it yet besides the over-the-frame headers. LOUD!
Tomorrow I'm going to change the oil and filter and try to get some of the wiring straightened out. I'm going to be busy with work right now and won't have much time to work on this.
Those souped-up headers required me to ditch the stock clutch linkage and go with a hydraulic clutch set up. The clutch still needs bleeding and adjusting.
After I get done with that I'm going to hang some mufflers on it and turn the pipes out in front of the rear tires.
Pics of the future cause of global warming:
tml
Ontario, Canada
I'm not sure how you get a 393 from a 351 but I have a similar set up. I'm running a 351W bored 30 over, mild cam, edlebrock perforner, new lifters etc. and a Q-jet.
Love it.
393 is an aftermarket 3.85" stroke crank with stock 351 rods and 302 pistons. The most economical stroker ever concieved for a windsor.
As for the heads. If they need work, save a few extra coins and get aftermarket. The '75ish heads don't flow all that well and with extra cubes they are proportionaly even smaller. But if on a tight budget and the heads are in good shape (nothing more then a new set of seals maybe) You could run them. Not highly recomended but doable.
I do recomend looking for dished 302 pistons. Compression ratios build very quickly on stroker kits. It is often difficult to keep them low enough to run on pump gas. So watch out there. Flat tops are good for stock stroke for a boost in compression. Strokers will take a bigger intake charge and squeeze it into the same head chamber as a non-stroked engine. So that alone will increase compression ratio, don't go too far by adding more with flat top pistons as well.
Edelbrock Performer cam and intake are a good choices. If you want to save a few bucks get the summit house brand cam for the 351W. It is the exact same grind and a few bucks less. But I would still recomend the Edelbrock intake over the knockoffs and house brands. The ports of the Edelbrock are more predictable.
Carb choice could be argued for pages.
BUKN76
Spanish Fork
WORLD makes an economical head for around $900...and trickflow will blow your mind for around $1400...but i think that would be overkill, unless you were looking to run a 12 sec qtr mile....although that would be cool, especially with a lift and 35's....
shop summit or jegs, they'll match anything else you can find. plus they get it to you fast
JWMcCrary
I kept a spreadsheet of all the parts with prices and part numbers when I built mine (393). Your welcome to it if you think it will help you any. PM your email if interested..will be Tuesday before I could send it.
My engine actually calculates 395 because it was bored .040 instead of .030. I wasn't very happy about that and it took forever to get the pistons but so far it has worked very well.
SteveL
Huge chevy guy
Hawthorne ca
You could look for a set of 69-70 heads.They flow better. Temps are fine with a solid cooling system. I also have good luck with the q-jet.You also may want to do a search about clearance issues if you run a stock uncut hood. It will fit with the right set-up.
recoiljunky
recoiljunky
Dothan, AL. USA
You know, I may have a set of 69 - 70 heads on my 302. I'll have to take a look.
I've got 2" of body lift and a desire for a hood scoop, so clearance won't be an issue. ;)
bmc69
the 69/70 heads have smaller combustion chambers..approx 10cc smaller. so keep that in mind when figuring out your final CR.
Bronco73
Cape Coral, FL
When I was going to build a stroker for my mustang i did a lot of reading on this site. http://www.corral.net/forums/index.php
Every one strongly suggested I get a custom ground cam for the build and there are two people on that site that do such work. but as always there is are a ton of things one has to consider when building an engine. that is if they are trying to build every thing to match yeilding the best performance for the buck/build.
recoiljunky
recoiljunky
Dothan, AL. USA
Hey Broncobowsher et al,
It's piston buying time. Octane is not an issue as long as they sell it at the pump. I'll also end up putting an aluminum top end on this.
Which pistons to buy? Earlier you recommended avoiding flat tops because of the resulting too high compression. Do you have any specific recommendation?
OX1
Depends upon what CC the heads are your getting.
I can't blindly recomend a piston. Too many things go into compression ratio. Deck height, chamber volume, even gasket thickness. You will need to know at least the chamber volume of the heads before knowing what dish to get on the pistons.
recoiljunky
recoiljunky
Dothan, AL. USA
I'm liking the price of the World Windsor Sr 200 and Jr 180 heads but truthfully, I don't know what size chambers I need.
What are the pros and cons of large vs small chambers?
I want to make sure I have plenty of torque. The motor is going in a toy, not a daily driver.
OX1
You'll have to play with this and see what compr ratio you end up with.
http://www.rbracing-rsr.com/compstaticcalc.html
Bore will be 4.030 (if 30 over )
Stroke will 3.5
Head gasket is about .043
Deck height (or deck clearance) should be .0145 with flat tops pistons (so I'm told
Piston top volume with flat tops is approx 4 cc (again, so I'm told).
CC volume will be 58-68 depending upon head you pick.
Looks like flat tops gets you 10.14:1 for the Sr's, 64cc chamber and 10.88:1 for the jr's 58 cc chamber.
Stroke will 3.5
Not so fast, it looks like he is looking at a 393 stroker. In that case you need to put 3.85 in for stroke (where I highlighted in red above).
Deck height is usually .010" (just a little different) but if the block gets decked they can often bring it down and zero deck the block, so the deck height is .000" (piston goes exactly to the top of the block.
Flat tops are usually around 4cc dish (for the valve reliefs)
The catalog I have on top shows flat tops and 64cc heads comes out to 11.5:1 compression. That's a touch high for gas that comes out of the corner gas station. I would aim for a low 10:1 compression ratio as a target for a fun weekend engine.
OX1
Missed (or ignored that one) :p. I thought deck height was the measurement from the center of crank to head surface? What is the true term of the distance from head surface to edge of piston at TDC (deck height clearance??) Also, doesn't the 393 use 302 pistons, should be a ton of choices for that (and is that why "DHC" is .010).........
Maybe it is deck height clearance. Whatever it is called it is the volume created by the piston not coming to the top of the cylinder. Most of what I have seen usually puts it at .010 under the top of the block. But I am sure there are other clearances it can be. One engine I have is the early 351 block, my pistons stick out above the top of the block by .013". Another engine was decked and the clearance was set to .000"
When I did the first 351 I was aiming for high 9:1 compression and going to test the limits of 87 octane. When I got the parts, found out about the short deck height, milled the heads to remove the reciever groove. It comes in at 11:1. Now I am testing the limits of 91 octane pump gas. On a warm restart I can get it to fire up like a diesel, my rattle start.
