NEWBIE Engine Question.
jallement1054
I went to look at a '77 eb with a 302 today that is for sale down the road from my house. My question is that when you first crank the engine up cold it has close to 50 psi oil pressure but one it warms up the pressure drops to around 10 psi at idle. what is the problem? oil pump?
Viperwolf1
electron whisperer
Probably worn bearings but 10 psi at idle is still within acceptable specs. I would consider it a high mileage engine.
HoosierDaddy
Agree with above , plus add you can move to a 30wt oil if you live in a warm climate , maybe 20w50 too. That will help keep the pressure up.
wildbill
Old Bronco Guy
:D :D :D Ford dosnt show a idle oil only at 2000 RPM and it should be 40 Psi. at temp. Good luck.:D :D :D Bill ;D :cool: :p
Wyflyer
There is some variety in guages also. Does it have any valve train noise? Does it increase if you throttle up and raise the RPM's?
Yes it's probably worn out. It will probably run a long time though. Would be better at 50psi but run it.
I had an engine once that I swapped out 4 different senders and got different readings every time. I finally put a guage in it and got what I considered to be a good reading, then chose the sender that was closest to the guage.
I don't trust senders.
Dave
I would consider the condition of the rest of the vehicle and the price more than the oil pressure which may or may not be an issue. If you are buying a 32 year old vehicle as a drivable used car you will probably face a lot of bigger expensive issues. Especially if you have to have the work done by a shop. If the price is right and you want a project grab it.
Rox Crusher
just make your purchase offer with the understanding the engine is high mileage and might have to rebuild it sometime in the future
I bet it lasts a while as is
J
jallement1054
With just a little throttle the pressure jumps up between 30-40 psi. It will be a project fo sure but whats funny is that the seller says that the engine only has 35000 miles since new 3 years ago
recoiljunky
Dothan, AL. USA
When I got mine, the stock 302 showed little or no pressure at idle (probably about 2 psi.) At 2000 rpm is showed less than 20 psi. It was a dog but it wouldn't blow up.
Jonboy69
What should they run at idle ? I just bought a 69 & it has a direct oil pressure guage & it is showing about 50+ @ idle. My old 73 with 100k on the original motor was barely 10 with the stock dash guage & it still ran like a top.
