NEWBIE - Question on Engine + Transmission
LW97
Newport Beach, CA
Hey all, newbie here, don't know a whole lot of technically stuff yet.. but I am about to get my very first Bronco, and cant decide between two.
The biggest differences I am seeing and have questions about is - one has a restored V-8 351 Windsor engine and a rebuilt C4. The other one has a brandnew Blueprint 306 crate engine (350hp) and a rebuilt c6 transmission.
Which one would you go with? Is one of them better than the other? and how much more are you willing to pay for the one you prefer?
Thanks for the help :)
jamesroney
Fremont, CA
Buu the one with the Fuel injection, 4R70W, and the roller cam.
There are pros and cons for the 8.7 deck 351, versus the 8.2 deck 302. It’s all about how you will use it.
The majority of people never make use of the power available in a well tuned V8.
I’d buy the Bronco with the least rust...
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The C6 is not a common transmission in an EB. It would make me question why the builder chose an oddball not widely used transmission instead of the much more commonly used options out there.
I don't think the C6 demands a premium at all. The C4, if it happens to be a true Bronco C4, would be the better choice for various reasons I think.
One easy way to tell if it's a proper C4 is if the filler/dipstick tube enters the pan, rather than through the side of the main case. I don't know what the other differences are, but either way the C4 is a better "fit" for a diminutive Bronco than the larger C6.
Even though the larger trans is also arguably the stronger one, ultimately it's a tight fit. Been done (obviously!), just not often.
The Blueprint engine sounds like a winner. Newer engine perhaps with a warranty still? Strong performer at 350hp it sounds like too. Maybe not the torquiest thing, but perhaps more than enough. That is not Blueprint's "Bronco" engine by any chance, is it?
The 351 is very desirable and there is a lot you can do with them.
What other features do the two Broncos have? Anything of note on either one?
Gearing? Axle upgrades? Suspension mods? If so, were they all done properly? Lots of shifty Bronco re-sellers out there these days. Can you say flippers that are light on facts? People to whom "Rust Free" has an entirely different definition than the rest of the world.
What about the use of bedliner on the interior? A great option, but often used to cover rust that should have been fixed rather than covered.
Did they send you literally crap-tons of pictures of just about every corner and hidden orifice of the Bronco?
Lots of stuff other than which engine and trans they come with.
I would not pay more for one over the other until I knew all the gory little details.
Good luck! And welcome to classicbroncos too.
By the way, are they nearby or do you have to travel or have them shipped to your location?
If long-distance, all the more reason to have someone go look at them for you, or do it yourself in person. Like I said, wayyyy too many dishonest, or simply clueless Bronco re-sellers right now.
And yes, even some of the professional companies that re-sell Broncos are not to be trusted without verification. Even some of the really good Bronco builders will flip a questionable Bronco now and then without fixing some of the stuff that will drive you batty when you get it home after having spent a full retail price on one.
Ok, I think I'm done. For now...
L
LW97
Newport Beach, CA
Hey Paul, Thanks a a lot for the thorough response! Very helpful!
I am quite drawn to the brand new blueprint engine. I am just not sure how reliable a rebuilt engine is. But also, the one with the brand new engine is quite a lot more expensive, so I am really debating whether it would be worth it to pay that price.
I will list out what each has below and links to the car.
1. https://rockyroads.com/project/1972-white-ford-bronco/
- Rebuilt V8 351 Windsor
- Rebuilt C4
- Dana 20 twin stick
- 4 wheel disc brake
- Hydro boost hydraulic power brake system
- 8 point roll cage
- 4.88 gears
- Dana 44 front
- Ford 9’’ locked rear axle
- 3.5’’ shocks
2. https://rockyroads.com/project/1973_ford_bronco/
- Brandnew blueprint 306
- Rebuilt C6
- Holley Sniper fuel injection
- Power disc brake
- 4.11 gears
- Dana 44 front (maybe, they are not sure)
- 2.5’’ suspension + 6 shocks
I actually saw both of them in person, will go look at them again probably this week. Let me know what you think.
Timmy390
Conway, AR
I don't like resellers. I know nothing about the seller
You should start a new thread asking if anyone has had dealings with them. Too may "lipstick on a pig" stories out there......
Tim
A rebuilt engine "can be" just as reliable as a brand new engine. As long as it was done correctly in every way, just like they would have done at the factory.
You're paying extra not only for "new" on the other one, but also for fuel-injection.
I don't like "locked" differentials on the street. Sure, it's driveable, but if you're never going to go off-road, why put up with the quirks even if they're small.
That said, most people use the word "lock" to talk about any type of traction device. Including using the word "Posi" with a Ford, which never made any sense at all to me. I'm not a purist for the most part, but I like accuracy. And a Posi-Traction is a GM limited-slip differential for GM axles only. So you can't put a Posi in a Ford.
Now, back to the difference, if the rears are equipped with "limited-slip" or "selectable" differentials then that's a different story and just fine on the street. Just try to avoid things like Detroit Lockers and the type.
What size tires to the two Broncos have? The gearing indicated should be good for many different sizes, but without an overdrive transmission then your tire size becomes even more important to how well it travels down the highway, as well as how well it gets out of it's own way when accelerating.
If the 4.11 Bronco has 38" tires, it'll be a dog. If the 4.88 Bronco has 31" tires, it'll be a rocket off the line but be hard to talk over the noise on the freeway! And if you're in Southern CA too, then freeways are a fact of life for most.
Both 2.5 and 3.5 inch lifts are very friendly, with the 2.5 perhaps being better simply because it's lower. But body lifts should be included in that factor, in case one has one and the other does not.
If you have family that are going to be riding around with you, or driving it themselves, see how they feel about literally climbing into the truck. If you have really young kids, you're going to be putting them in yourself anyway. And older kids love jumping up into the Broncos on their own. So kids are not an issue.
Older parents are a factor, but that's an individual thing. But if your wife is not happy with the situation, you might not be either!
In addition to the tire sizes, what type of tires are they? Mud tires are the rage because they look aggressive and purposeful on a rig like a Bronco. But all-terrain types are way more street friendly.
Hydroboost bakes are more powerful than just about any vacuum boosted brakes, based on what would fit into a Bronco under the hood. You can get very powerful vacuum boosters, but they just don't fit under the hood of a Bronco. So hydro is an advantage. And more expensive...
Four wheel discs are great, as long as the rears still have a working parking brake. That would be something to check out for sure.
If you're not too far away from them, by all means spend as much time as they'll let you crawling around and familiarizing yourself with the little details of each.
They have a personality all their own, so best to be comfortable with it when it decides to surprise you with something new.
Good luck! I'm I'll have more junk to spew forth with, but I'm empty for now.;)
L
LW97
Newport Beach, CA
Hey thanks for the response!
Both are rust free supposedly. and both are 3 speed.
Does it matter that one is a restored engine and one is brandnew though?
Which one is better for daily driving city+highway?
Neither nor...
It's all about the whole entire combination of things. Not how new, or even how big sometimes (though bigger does still matter in the engine department sometimes).
It all depends on how the rebuilt was built, and how the new one is set up. Even though it's new, the Blueprint is still built to their specifications on every internal component.
If corners were cut on the rebuild, there's just no knowing how it will drive, how much power it will have, or how long it will last.
The 351 naturally has an advantage in torque production in the lower rpm ranges than a 306 does. A longer stroke and an overall larger displacement means that in stock trim the 351 will pull around a heavy Bronco more easily.
But where a stock 302 was no power monster (roughly 140bhp), a Blueprint performance engine is no slouch in any category! I'll have to go look at the dyno charts posted on their website (if there are any) to get an idea of how it might fare in a heavy Bronco with the wrong gearing.
By "wrong gearing" I mean it's back to the combination. What tire sizes between the two rigs is going to make a huge difference. You can't get 350 horsepower to the ground if you've got 44 inch tall tires and 4.11 gears!
In other words, the road manners and how it feels are all about the whole combination.
Both the C4 and the C6 are old-school 3-speed autos. The C6 is larger and stronger, but the C4 is a much better fit for an EB (Early Bronco). The transmission gearing is near enough the same, but the "final drive ratio" is what counts. That's the combination of differential ratio (known) and tire size (unknown as of yet).
Do they let you take the vehicles for test drives without too much drama? If so, I would drive both and see what you think. Ultimately you're the final factor in the equation.
If you come back with a smile after driving one, but wanting to change your underwear after driving the other, then there's your best indicator!:eek:%);D
L
LW97
Newport Beach, CA
Not sure about the tire, but i know the 4.88 has 18'' wheels, and 4.11 have 17'' wheels. (I hope this means something too haha)
The blue bronco is actually on consignment, and apparently the owner previously tried to restore it somewhere else and they messed up a lot of things costing her a lot of money. To be totally transparent with you the price difference is 20k+ (the blue one is way more expensive). I understand now that I am paying for not only the brandnew engine, but also the fuel injection (and probably power steering too?) And the blue one's body is also really well restored with a great paint job. but is the 20k worth it? I am questioning if it's so much of a difference because of the money the owner previously spent (Wasted) on the bad restoration.
Possibly, but a lot of that extra cost sometimes comes down to the paint job. Big ticket item and one that really sells Broncos these days.
But it's always going to still come down to the overall worth. Not how it compares to another Bronco, but how it compares to the market, or what you are really looking for (when you know exactly what you want, which is not always easy!) too.
If you can make up the difference for less than the $20k difference, then on paper it's not worth the difference. But if it's still within the ball-park price wise for what others are paying for similar Broncos, then it's totally worth it. It just means that the other one is a "good deal" where the more expensive one is "fairly priced" or something along those lines.
See what I'm getting at?
Basically the engines and even a few of the other listed parts are definitely NOT worth an additional $20k. But there's a lot more to consider too, than just those items.
Sorry I did not have a black-n-white answer. Too many variables in just the collector market aspect. Also too many variables in all the rest of the vehicle details.
L
LW97
Newport Beach, CA
Haha yes at the end of the day the test drive will probably tell me a lot!
The 4.88 gear has 18'' wheels. 33'' tires! I actually got to test drive this one, it was powerful, and had plenty of torques. Loved it. The steering was a little too loose so if i do go with this one i will be fixing up the box and adding a tilt steering too.
Actually the other one may be a 3.5 gear not a 4.11, I am double checking with them though, tires are about 31''. But again, not sure about these still they are double checking. Haven't gotten to test drive this yet. Looking forward to test driving this soon
No worries you have been extremely helpful!! Been learning so much talking with you. Grateful for your time :)
Well there's your perfect example. Normally we say "don't fear the gear" when choosing differential ratios to go with an overdrive transmission and larger tires. But in this case, they did not fear the gear but only have a non-overdrive transmission!
So yes, you felt the power getting to the ground because those 4.88's really let it sing out.
But running down the highway your engine will be spinning up to the tune of almost 3600 rpm at 70mph!!!!
It's not that it will harm the engine to spin that fast (it could likely go to 6500 without trouble) but that's way too high for normal driving.
If you rarely plan to get over 55mph, it's probably a sweet combo. But you'll be making sure to keep ear plugs in your rig for driving out on the road if you try to keep up with traffic.
Between the drivetrain noise, road noise, tire noise, wind noise, engine fan noise and exhaust noise, you will not be able to carry on a reasonable conversation or listen to the radio while humming along at 3500 rpm in a Bronco.
Not unless part of that finished package includes lots of insulation everywhere, and air-conditioning!
The 4.11 and 31 combo on the other hand is a very common happy medium for more off-road and acceleration, but acceptable highway running. It's still high, at 3200 rpm @ 70mph, but it's just that much more easy on the ears.
If it's got 3.50's however, that puts you at a much more reasonable 2700 rpm at that speed. MUCH better!
A little slower off the line, but not enough to upset anyone.
Now you see why more and more of us are fans of overdrive transmissions. Always thought an "over/under" six-speed would be ideal. You could have your granny low and your overdrive, but with a normal 4-speed in the middle.
Best of all worlds maybe!
sprdv1
REBEL
I'd set a budget, go w/the one within that budget and best overall condition..
sprdv1
REBEL
Welcome aboard as well.. Key thing is be patient, find the right one. Don't just jump at the first one
Timmy390
Conway, AR
I'm not a fan of the C6 at all. Big heavy transmission with lots of power loss. It's designed to be in big heavy cars and trucks. I have one in my 69 Mach 1. HATE IT.....The trans not the car.
Tim
L
LW97
Newport Beach, CA
Thanks! Yea going to see a few more this weekend. Almost jumped on the first ones I saw, but thankfully found this forum and got a whole lot of good info
Timmy390
Conway, AR
Have you looked at the for sale by member section?
Half cab in VA is nice......
Tim
