Newbie - STC Doors - How do they attach, on NEW to me Bronco
mytmouse75
Medford
Hey guy's just getting back to the Bronco after being away for a bit and the Holidays and all.... Hope everyone is enjoying the Holidays....
Up next - I've been wanting to figure out/fix the STC doors.
As far as the STC Doors go, as mentioned in the beginning of the looooong post I had posted when I first got the Bronco, it looks like from the body and paint work they filled in where snaps would've been and/or any kind of bracket holes, etc.... - See link of pictures below - what am I missing, HOW do the doors attached to the windshield pillar ?
I cleaned them up quite good reshaped and painted the door frames. I've been experimenting with different kind of handles to replace the missing ones, and I'm changing the snaps (on the soft door) to black snaps. I think I'm going to use industrial Velcro in place of the snaps on the body, maybe up the windshield pillar too. I painted the bracket black, where the front of the doors slide into and hinges on. I figured with the black velcro and the bracket black, would create one continuous black line at the door opening edge.
I just wanted to know how / what's missing to attached the doors the the windshield pillar...
https://goo.gl/photos/wtsWYAr3sy5TyKcp8
Thanks,
-TC
WILDHORSES
USA
You need 1/4" square aluminum about the length of the channel on the side of the windshield. Slide the aluminum into the small slot at the front of the soft door wing window. Once this is done it folds into the channel on the side of the wind shield frame. A small sheet metal screw can be used to hold it in place. Add three snaps to your front fenders and that about it. O hope some of this make sense.
Jim
bbow
Ozark, Alabama
Kayline / STC Information
Here's some stuff I dug up. I had a set at one time.
mytmouse75
mytmouse75
Medford
Sweet Thank you Jim !
That's just what I've been searching for.
I had contacted Wild Horses also, and they were able to supply me an Install sheet with drawing pictures/diagrams. They just weren't sure on the size of the Aluminum tubing.... Now we know it's 1/4".
The sheet metal screw - your talking about is to hold the Aluminum tubing within the soft door in the slot/pocket of the fabric next to the vent window -right ?
***Thank you and to all @ Wild Horses ! ***
Have a Happy and SAFE New Years !
STC Convertible Doors
Install sheet with drawing pictures/diagrams:
https://goo.gl/photos/WCbiHaXwVbpQJNyt9
640 North El Dorado Street Stockton, CA 95202 Phone (209)943-0991 Fax (209)943-7923
www.wildhorses4x4.com
#3253, 3255 Date 9/13/06
Parts list:
1 - Right door frame 2 - Door handle sets
1 - Left door frame 8 - Snaps
1 - Pair convertible doors 1 - 80” Velcro
Hardware list:
2 - Bottom hinge plates
2 - Aluminum square bar
2 - Aluminum extrusion
24 - Screws
Door inserts are also required
Note #1: Please note that in order to install doors properly you will need a helper. Depending on your skill level, patience,
and meticulousness this job should take between 3-6 hours.
Note #2: The diagonal measurement from the corner of the windshield to the rear edge of the door insert should be 33
3/4”. This is critical for the proper fit of the new door. To adjust the windshield loosen the bolts through the dash
and shim the windshield frame. Check both sides at the same time.
Note #3: Many Broncos by this can be overcome with a few adjustments. This instruction sheet is to be used as a
guideline. There will be slight variations from one Bronco to the next.
1. Figure #1 shows the location of the door hinges with the door insert already in place.
2. Locate top hinges as shown in Fig. #2. Measure 4” from the top of the windshield frame to the top of the hinge. Drill 2
1/8” holes and screw into position.
3. Insert door frame as shown in Fig. #1, step 3.
4. Push the bottom of the door frame back as shown in Fig. #1 step 4 by the arrows. When proper clearance for the door
frame has been obtained over the top rear ledge of the door insert, place a mark as shown in Fig. #3 as a locator for the
bottom hinge plate. This should be approximately 33 1/2” frome the rear of the door insert. Remove door.
5. Locate the hinge plate as shown in Fig. #3. The outside edge of the hinge plate is 1/8” from the edge of the door insert.
Mark in proper position and drill holes. Use a 1/8” drill bit for B and 9/16” drill bit for A. Screw plate into position.
6. Insert door frame and check for proper clearance. The door should open with minimal amounts of effort.
7. Attach the canvas door to the frame shown in Fig. #4. Cut the velcro as follows: 2 ea. 1/2” - 8ea. 2” - 6 ea. 4” - 4 ea.
14”. Match the cut of the velcro on the canvas and attach to framework Fig. #4.
8. Slide the aluminum bar into the sleeve in the fabric next to the vent window and slide the aluminum extrusion into the
position as shown in Fig. #4.
9. With the door on the vehicle mark snap positions at the front of the door insert. Drill 1/16” holes in the door insert
and screw down snaps. The positions should coincide with those in Fig. #5. Using the holes in the aluminum extrusion
as a guide, drill into the insert, then screw into place. Next, open the door and push the sleeve containing the aluminum
bar into the rain gutter on the windshield frame.
10. Assemble the door handles as shown in Fig. #6. It will be necessary to cut a hole approximately 7/16” in diameter in
the canvas to facilitate the handle.
mytmouse75
mytmouse75
Medford
WOW - thanks all for the replies - I replied to Jim and then I saw all y-all replied too, with helpful info - thanks !
I'm running out the door now , but I'll have to read that other thread on the kayline door install...
Does anyone have pictures of the door / windshield portion?
catfan
You can also use 1/4x1/4 steel in the windshield gutter as long as you paint it , it's 21" long.
garberz
Bronco Influencer
Conejo Valley, Ca.
Mine are the stock Kayline hardware, they're painted steel. They slip in from the bottom, just above the three snaps. I made some retainers from 1/2"x1/2" aluminum angle.
Now you get to figure out something for mirrors.;)
Mark
mytmouse75
mytmouse75
Medford
Thanks, all. I haven't seen the angle retailers in the documentation or used before. Are they really necessary, if the 1/4 x 1/4 tube fits tightly enough in the windshield channel with the fabric?
catfan
It does fit tight in the channel, you shouldn't have any problem with it coming out.
