jetsg4
i fired up the truck today, and it ran for a while, then just died. it was a strange die like someone turned the key off, and wouldn't start again. NO FIRE. so far i have replaced the ignition box, coil, and the pickup coil. STILL NO FIRE.
for some stupid reason, i forgot about the small electrical fire i had last weekend. i thought i had all the damaged wire replaced, but i guess i didn't. after i repaired the wire last weekend, i was going down the highway and it died like the key was turned off, and it did it wednesday night also. all i had to do those times was pop the clutch. seems like a wire is grounding out somewhere bouncing around going down the road, and it just isn't moving right now.
my question:
getting out the old multi-meter tomorrow, what would be a good path to follow to check for shorts?? with the key on, it's hot to the ignition box and hot @ the coil. i'm noticing a difference with the tach though. when the key is off, the tach usually reads straight down(gravity) @ 1k rpm. when the key is turned on, it usually kicks to 0 until the engine starts. now it is bouncing all over the place between 0 and 1200 rpm.
my question:
