I've been having the same problem as described above. Bronco drives along nicely, then it dies just like the key was turned off. I had the electronic ignition module tested and it tested as failing, so I replaced it. That wasn't the problem. I pulled the wire off that runs from the coil to the distributor and had my wife turn the Bronco over, and I only got spark when the key was released. I could use some help in figuring this one out. Any ideas?
