- Oct 19, 2005
- 2,729
Ok doing a full rebuild on a Sep. build '66 U13. I'm in the final stages of testing electrical but I have no horn or stop lights. I did put in a new turn signal switch when I rebuilt the column. Also carefully went through the original dash harness, engine bay harness for broken connections all seems to be good.
So everything works as they should turn signals, running lights, headlights, and tail lights, even all the lights in the cluster but stop lights or horn. I'm getting 12v to the circuit that powers those two components. These both should work if the bronco key is "on" and/or "off" but no go in either case.
Any help would be greatly appreciated!
Thanks Jeff
Thanks Jeff
