Aggie_Bronco
- Dec 27, 2013
- 8
Howdy y'all! I apologize in advance if I use the wrong terminology; I'm way out of my depth here. I've got a major problem with my engine. It started out just not really wanting to run when it was cold out, refusing to start, dying at some idles ,etc. Then this past weekend I was driving at it got so bad that it would only run if I got out, poured a little bit of gas into the carburetor, drove for 40-50 yards and then did it again. (normally would never do this, but I got stuck in the middle of the highway and had to get off somehow). Then it warmed up a little bit here in central Texas and I got it to start and run a little bit, but if I wasn't actively pressing on the gas it would die again. I was on my way to bring it to the shop, and had driven no more than 25 feet when it stalled out. No biggie, I'll restart it. I do crank it, and it runs for a second or two before shutting off again. silence for a second or two then it made this funny noise halfway between a grind and a pow! and smoke starts pouring our from under the hood. When I opened up the hood, I see that its pouring from the carburetor. After I pulled the air filter off, I was able to see it smoking still. I blew the smoke away and let if cool off. I then tried to start it again, after a few failed attempts it started and now runs really crazy. It sounds like I'm revving the engine for all its worth, even though I'm not touching the gas and the manual throttle is not engaged. It also picked up a squeak. I'm planning on getting a friend to tow me to a shop, but I was wondering if any of y'all might be able to tell me how badly I could have screwed up?
