orange69
- Feb 10, 2002
- 309
My bronco had been sitting for a few months and now will not start. After doing some quick testing (air, fuel, spark) it still will not start. I originally thought it was just bad gas but it would not fire even with starting fluid! I checked for spark on plug #1 and it was there. It has a Pertronix Billet Flame Thrower II distributor. I've been searching all over and found a few things to try, but it just leads me to more questions. I checked the timing with a timing light and even though its hard to read, it looks to be ok. By that I mean it is firing within the timing marks on the balancer. Looks to be around 8. But here's my question. When the motor is turning over, the spark is not consistant. Its not the steady blink, blink, blink, its more blink, blink,...........blink....blink. (Sorry I'm trying to describe it as best as I can.)My guess is the ignition module is bad? I though maybe my timing light has a short, but I tried it on my other bronco and it worked perfectly every time. Since the motor isn't running, it that why the spark isn't consistant? The bronco ran fine when I parked it a few months ago.
When I crank it over, it acts like it wants to fire, but just sputters a few times, then nothing. It did once kind of backfired through the carb, which is why I started checking the timing. It kinda made a "whump" sound and that's when I noticed the carb was on fire! Of course I was dumping a lot of fuel down the carb trying to get it to fire. Even though I'm getting spark, is it not firing because its not consistant, more of a sparatic spark?
