I have a HF quad lift that I put a plywood deck on to support my 435/D20. I used a small scissor jack to rotate the assembly into the correct clocking. Beauty is, it would fit right up inside the dual exhaust so I didn't need to remove it. Since it is on wheels, I could use a ratchet strap to pull the assembly into place. I hope I made that sound super simple. It was not. I'm not sure what was fighting me but it took a bit to get everything exactly aligned. Also, I took a couple of 1/2" bolts with a smooth shank, cut the head off so I had about 1.5" of smooth bore available, tapered the end and then cut a notch across the top of each one for lower guide pins into the bell housing. Once the things slips in, just use a flat bit screwdriver to remove the guide pins.
