np435 with no BLtt
NorCalBronco
I did a search and couldn't find anything to answer this. Has anyone installed a np435 without a bodylift? I just picked up a really nice np435 w/ adapter but dont have a bodylift on my bronco. I dont mind cutting but I dont lkike bodylifts :/ Can it be done?
pdxbronco70
Portland
The PO installed a NP435 with no body lift on my '70. It just takes some cutting and refitting of some sheet metal.
ManTruck
The 1" lift is a pretty easy install, very hard to see, and makes for much needed room.
I wasn't a fan until I installed my 1" WH body lift.
mudstud
Bronco Bonehead
Excel
I tried the install with a 1” body lift. As pdxbronco70 said it would still take some hacking on the tunnel to get it to fit but you could make it fit. I bit the bullet and bought a 2” body lift. The install went much easier.
Fishmanndotcom
senoia, GA
after trimming the tunnel cover a lil mine fits perfectly! i love how it tucks away in there. i run no body lift! just mucho fender trim :cool:
-cutts-
NorCalBronco
NorCalBronco
Im glad to hear it fits! I had a 3 " BL on at one time before I could afford a nice suspension lift and just didn't like it. I like to keep as low as possible and think my 3.5 WH lift and 35's is perfect. Cant wait to get the np435 in there and walk next to it idling up a hill hehe :)
broncnaz
I did the swap with out a body lift just means you have to cut a bigger hole in the tunnel to fit it but it does make it nice to have a large hole to get at stuff from the top. But I think at least a 1in body lift would help clearnace issues mine hit the heater front edge of the heater box(broke it had to fiberglass a new front edge in) but my stock body mounts were pretty bad off at the time. So that could have made a differance.
ET
Dallas, TX
You will need to bend the shifter alot more if you don't have body lift. To clear the dash.
Eugene
allenfahey
It can be done. These measurements are for no BL. Measuring from the 45 degree bend up towards the defrost duct on the right side is 4" up and 6" towards the rear with a 1" lip to the crease towards the floor. On the left side it too is 4" up to the air box and 6" towards the rear with a 3/4" lip to the crease to towards the floor. If you need more explaining let me know. You will be cutting a crossmember but nobody has had any problems before about doing it.
Pa PITT
Stephenville TEXAS
We did my running buddys 1st.. it was 200 cid with a 2 inch it went perfect ....
mine was much harder v8 and no lift .....well it takes a large hole for trans to fit thru then it needs shifter bending...and after all was over I put too long of screws in the cover and it bumped when I shifted gears took forever to figure this out ....they were 2 inchers .....but it bumped hard and then I put a 1 inch lift on it or on top of the factory bushing that were there already...worked out great ...all was well...
raleigh_bronco
Another installation with no body lift. Although I had to curve the shifter to clear the dash. It almost looks like a snake. :)
BUCKETOBOLTS
Salisbury, NC
I first installed my first NP435 without a body lift. I cut the entire top of the tunnel out and made a removable cover. This allowed better access to the transfercase linkage and bolts. Then I later installed the 2" of body lift. I believe it should have came from Ford with one. Everything is much easier to work on. And I still like my removable cover. Lets me use my cherrypicker throught the pass side door to take the tranny in and out. My rig has grown so that my jack will not reach high enough without taking the tires off and setting the axles on blocks.
GrantMurray
Austin, Texas
I used the WH 1" body lift as well, can't really tell that the bronco has a BL. I tried it without it first, but just didn't want to cut anymore. After the BL, the NP435 went in smoothly. Then I made a removable cover out of diamond plate stock. It's awesome, I kept my 3.5 gears for highway travel, but it's damn low enough for me when I want to use 4L.
