NV3550 Dimension Help Needed
dnewman9
I was just about to button up my engine tranny and tcase but I am having some issues with my throw out bearing.
I think the problem is the clutch that a 4.6 uses is shorter than the standard 5.0 so when my throw out bearing slides along the input bearing cover on the nv3550 it slides off the end. I am not sure if there are different lengths of input bearing covers but I think I either need to find a longer unit or have someone make one for me. There is 5/8 of an inch from the end of the input cover to the clutch fingers and it takes 3/8 of an inch of throw to fully disengage the clutch. The throw out bearing is 1.36 inches wide so at full extension only .36 inches of the throw out bearing would be on the tube. If I could get it extended 1.25 inches, 1 inch for the travel and .25 for safety the throw out bearing would be on the tube the entire time? Do you guys think that cast cover could be extended? I don't think there is any real force on it other than the sliding motion of the throw out bearing?
Alternatively, could someone tell me the length of their nv3550 input bearing cover? Basically the distance from the base of the tube to the end where the splines are exposed? Mine measures about 3 inches.
D
dnewman9
after looking things over, it looks like my input bearing retainer has been cut. The tranny came out of a guys jeep with an LT1 swap, I wonder if he had to cut it to fit it in?
Could anyone with an NV3550 sitting in their garage confirm the length of the stock input bearing retainer for me?
Dennis
