NV3550 Overdrive Question?
broncoitis
Is there any way that anydody knows of inproving the overdrive in the 3550? Like taking it from .78 into possible low .6 or high .5 range?
This would definitely improve the mileage at cruising speeds compared to the .78 it currently has!
I like my 3550 just wish that the OD was a little bit better!
Whoaa
I don't have an answer, but interested because I'm trying to decide what OD manual transmission would be best for my application.
For clearification are you saying a slightly lower 5th O.D. gear ratio would work better for your application?
If so, why? Increase engine RPM for better performance, gas mileage, some other reason?
What size tires are you running, what gear ratio in the diff''s, and approx how much tourque and HP does your engine make?
KyddsPly
I'm running the transmission. Pushing on 35 with 411 gearing at 70 miles an hour I'm about 2300 RPM. It would probably be easier to read gear the differential.
Like said, probably easier to swap diff gears. But of course that changes all the gears. Not just the overdrive.
Probably not much call for gears in that particular trans. Popular swap unit of course, but for hi-po installations (which arguably drives most changes to parts like this) most don't use 3550's.
And most 3550 owners would not want to go taller anyway. Their engines couldn't tolerate lower than 2500 while pushing their EB's through the wind at 70mph. Much less lowering below 2000! Most of our engines just don't build the torque to run a heavy aerodynamic-less brick at that low of an rpm.
In those cases, not only would you likely not see an improvement in mpg's, but it might get worse due to lugging the engine down out of it's comfort zone.
I can't think of any normal transmissions with a .5 od ratio in fact. Might have reliability connotations, or it might just be that it doesn't work with the power-to-weight ratios of most trucks.
Good luck though. Can't wait to hear what your gear ratio and engine combo is right now. Many of the conversations around here on this subject revolve around going lower than 4.11's, and even 4.56's with their 3550 combos.
You already running 4.88's or lower? If so, and you wheel it as well as drive it on the road, I could understand wanting a little higher overdrive.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
AX15s (the Aisin twin to the NV3550) have the ability to upgrade to a .69 Overdrive gear. Given that all the adapters are interchangeable between the two, this may be your best option to get a decent OD gear.
I plan on doing this to my 5.0L powered Toyota in the future.
For your reading pleasure:
http://www.pirate4x4.com/forum/toyo...earbox-r150-r151-r452-dyna-5th-gear-swap.html
Your mileage probably won't improve by much however.
broncoitis
broncoitis
I am currently running 4.56 with 35's. Looking for the better overdrive to lower the RPM of the engine at highway speeds. Mostly 70ish MPH which seems to be the flow of traffic these days.
I understand where Paul is coming from with the aerodynamic disadvantage of the Bronco to begin with but feel that unless I am pulling a hill that my engine has more than enough grunt to keep things moving along. Having said that, if I were to move down to a 4.11 the performance would suffer a bit as well. I think that with a mildly built up 302 a 4.56 gear with a 35 inch tire is really a perfect combination. If the OverDrive were a bit better than .78 the world could truly be perfect. .10 doesn't seem like alot but it would probably bring down the RPM's just enough to put the engine at a much better cruising RPM where the engine doesn't sound like it is working too much for the given speed.
Current 6 speed tranny's seem to be the ultimate compromise with two overdrive ratios to work with. With the rise of the overall speed limits to roughly 70 MPH, a better OD would work better for me than the current option in the 3550. Seems to me that most trannys available for daily drivers are geared for a time when the maximum speed limit was 55MPH. However, that isn't the case anymore and keeping up with traffic at 3000+RPM on the tach is not going to maximize the gas mileage at all!
Basically I am looking to lower my engine's RPM while driving on the Highway keeping up with traffic. 3000+ just seems to high to me! The AX15 sounds like it could be a solution. I have no doubt that it would definitely improve the gas mileage because the engine would still be operating in the sweet spot IMHO!
I mean there is a reason that cars have 7 and 8 speed trannys these days and fuel economy is a big reason to do with it. A lower cruising RPM while still keeping the engine in its powerband should maximize the gas mileage in all our beloved Broncos!
Hopefully this makes sense!
bronconut73
I feel ya' but our unaerodynamic lifted Broncos with big tires need more rpm than modern highly aerodynamic trucks and cars do to maintain speed and good mileage.
But I understand wanting the best of both worlds. I want it too.
blubuckaroo
Grease Monkey
Ridgefield WA
I consider, a bit less overdrive than the automatics, to be the NV3550's advantage. It's actually useful in a Bronco.
I have a NV3550 and do like the ability to cruise down the freeway at 70-75 MPH without hearing a winding engine. The .78 ratio has provided plenty of overdrive for me to do that.
You're going to find the limit for good fuel economy in a Bronco, is at about 60 MPH, even with perfect gearing.
xcntrk
NOVA
I have the opposite problem with my NV3550. The OD gear is really long legged and it's difficult to maintain sufficient RPM at highway speeds to overcome the aerodynamic disadvantage. I'm running 4.10's and 33's and ideally should move up to 4.56's instead, but the 1-4 gears are at a fine ratio for street driving. As a result I rarely use the OD. Really only on the Interstate where speed limits are 65/70MPH does it get used. For state and rural highways at 55MPH, 4th gear at 1:1 is ideal.
Seventee
In the sticks of MT
... With the rise of the overall speed limits to roughly 70 MPH, a better OD would work better for me than the current option in the 3550. Seems to me that most trannys available for daily drivers are geared for a time when the maximum speed limit was 55MPH. However, that isn't the case anymore and keeping up with traffic at 3000+RPM on the tach is not going to maximize the gas mileage at all!
It doesn't make sense. With your tire/gear combination you shouldn't be turning 3000+ at 70mph unless you are in 4th gear. Are you sure your speedo is correct?
Slednut10
Guru? That's funny!
My suspect math skills say you should be at roughly 2400 RPM with the 35's, 4.56 gears and .78 OD. Is it possible your fan is noisy as hell at highway speed? My stock fan is and the noise it makes doesn't match what the tach is telling me.
SHX669
A couple of things ; I don't know if there is any " perfect gearing ' at least in my experience I either have to lean toward Hiway use or offroad. So I generally pick what I want from that rig - But of course not everyone wants the same " driving experience "
Secondly ; some people Overemphasize "driving in the powerband" especially when it comes to gas mileage . I know the newer rigs with variable valve and ignition timing are different than our Broncos running carbs but my F-150 with 360HP @ 4000 rpm or so goes down the highway at 2000rpm plus or minus -- for --- gas mileage!
I'm running 3.50 gears with 33" and a 351c {2v heads ,holley truck avenger , MSD ready to run distr., RV type cam } I frequently use overdrive at 60 mph when the road is level or even slightly up hill of course I have to shift down on steeper grades . I tow my 2000# travel trailer in overdrive -- on the semi flat freeways - but try to do 70mph then with the xtra weight and air resistance.
I've been considering dropping down to 4.10s but would NEVER go lower than that for the way I drive this rig - I don't like driving down the freeway for 2 hours at 3000 +rpms. - but that's just me and the driving experience I want.
SHX
Apogee
Tangent, OR
NV3550 with .73 overdrive (same for both close and wide ratio trans if I'm not mistaken), 4.56 gears and 35 inch tires...your math smells funny.
3000 RPM = 94 MPH
2237 RPM = 70 MPH
...or maybe your tach is inaccurate. Regardless, something doesn't add up here. If it's just a noise issue, quiet down your exhaust, add sound insulation on the floors, doors, top, etc, and see where you fall. As noted above, some fans can be quite loud...I know the 19" flex-fan on my F150 is borderline obnoxious.
SHX669
I have better luck with these rpm/gear calculators by using the actual height of the tire as mounted on the Bronco.
Using that idea - my calculator says that with 4.56s and 35s and .78 OD - 70mph =2526 rpm.
Our 35" BFGs are actually 33.5" " sitting height " as mounted on the Bronco.
bearskinner
N.Idaho, AK, SoCal
I am currently running Goodyear Kevlars 35/12.50/15's on 8" wheels and they are just about 35", maybe 34.75" with my NV3550 I tach right at 2500 RPM at 75 MPH, and almost wish I had lower gears, not taller. I also do at least 1000 miles a year in 4WD rough terrain
broncoitis
broncoitis
I think that it could be that my tach is off and maybe not grounded well enough. All I know is that my tach is around 3k with me cruising at around 75 MPH. When I become more mobile I have alot of things that I have to get done before SC. I am planning on attending and want to drive the Bronco even more this year and the coming years. I think that a change in tires could also be in the near future! I really like the new BFG AT with the aggressive looks. Gotta definitely check the Tach though because I think that I am being fooled. LOL!
