- Nov 11, 2007
- 7,842
Edit: fixed see last post
My clutch pedal is stock bronco, same for clutch bracket mounted on frame to redirect arm. Clutch arm to clutch fork and fork stock.
I have an NV 4500 with dual clutch I think it's the big orange one. Use the throwout bearing for the clutch.nv4500,
I'm trying to dial this in but issue is I do not get clutch movement/disengagement until about 2 inches off the floor, and to get that I had to adjust clutch fork rod, the one off the frame bracket a little more than I would with stock ford clutch, there is no endplay.
Basically, I have to push the clutch pedal further than anything I used on a ford. Not bad just different. Anyone else with an nv4500 notice this? Can;t find any comments like this in forum search.
